Car unlocking it self! WTF
oguz327
Captain Armco
Captain Armco
Sun Aug 24, 2008 7:22 pm
Just wondering if any of you have had the same problem?
For the last 3 or 4 months this has happened and about 4 times now, at first I put it down to the dealer fit alarm playing up, Tomtomis removed this for me a few weeks ago but then today when i went to the car it was unlocked again :evil:
Now i know for a FACT i locked it last night so WTF is going on, either someone has been playing silly buggers or the central locking relay is playing up maybe?
Anyone else had this?
lukescott
Sun Aug 24, 2008 8:19 pm
Haunted :mad: :mad: :mad:
eko
Old timer
Sun Aug 24, 2008 8:28 pm
I would start with the relay.
oguz327
Captain Armco
Captain Armco
No one else had this problem then?
If someone has been f#cking with my car I think I know who it is anyway.
oguz327
Captain Armco
Captain Armco
Sun Aug 24, 2008 8:30 pm
eko wrote:I would start with the relay.
Cheers Tony, will try a different one and see what happens.
Thinking about a new alarm too
d6dph
Sticky locking motor?
I know on some of the kits I have seen, The master solonoid sends the signal to the slaves to lock, If this one sticks it will unlock the car after a while.
Not 100% sure how the E30 set-up is though?
Jon_Bmw
Dangerous when thinking
Sun Aug 24, 2008 8:31 pm
As a precaution you could deadlock it tonight? The only slight issue is if it spends all night trying to unlock despite not being able to because of the deadlock?
Rosc0PColtrane
Sun Aug 24, 2008 8:32 pm
Disconnect the battery after locking it....... :mad:
oguz327
Captain Armco
Captain Armco
Sun Aug 24, 2008 8:36 pm
Jon_Bmw wrote:As a precaution you could deadlock it tonight? The only slight issue is if it spends all night trying to unlock despite not being able to because of the deadlock?
Cheers Jon, I deadlocked it earlyer and removed a few key components so the car wont be going anywhere tonight
Sun Aug 24, 2008 9:23 pm
I had a similar problem when I first bought my 4 door, I would lock it and it would unlock itself straight away, cant remember exactly what it was but I fitted a new door barrel kit and replaced a few electrical joints along the way. Have you done the Red/Black wire thing yet? Just check out all the joints while you swap the relay over
Jon_Bmw
Sun Aug 24, 2008 9:28 pm
Rosc0PColtrane wrote:Disconnect the battery after locking it....... :mad:
Its been a long day. As its in the boot, you'd have to lock the doors and boot manually afterwards. Or use the connector in the engine bay I suppose.
ha22
Sun Aug 24, 2008 9:39 pm
check the connecter between the door and the body, most likely a loose connection or a bad connection due to corrosion. also check the cl relay for any water damage.
oguz327
Captain Armco
Captain Armco
Sun Aug 24, 2008 9:57 pm
Cheers chaps, will properly investigate all the things you have mentioned tomorrow and see what i can find.
Sun Aug 24, 2008 11:35 pm
It will unlock if the locking ECU thinks the driver's door isn't shut.
Mon Aug 25, 2008 7:53 am
Oz. My moneys on the drivers door accuator i.e. Dave is on the money above. Speak to Barry see if the locking works okay on that iS he's breaking. I'm sure he'll let you trail fit the drivers to rule it out.
HartgeH27
Mon Aug 25, 2008 8:17 am
Got a central locking CU spare if you need one to try - freebie !
