I've got a problem.
Next to the oil pump, underneath in the block casting, there is a threaded hole. it goes directly into the oil gallery. I never took the engine apart and i'm assuming their should be something screwed into it, as i'd immagine their would be no oil pressure with it left open. So can tput the sump on until I find out what if anything should be there!
Short of ringing BMW and getting a schematic drawing sent through Fax.
See red circled part in pic:
Thanks.
