red and black central lock mod - access to speaker
danman2k
Wed Aug 06, 2008 7:19 pm
hi, i am going to do this mod as my central locking is now playing up. my question is how do i get to the speaker properly without damaging the plastic cover?. thank you
for the benefit of other searches, here is the mod
Remove the driver's footwell speaker and find two seperate red/black wires going to two seperate pins of the driver's door socket. Cut both of these wires and join together the two ends which don't go to the socket.
Chris-W
Wed Aug 06, 2008 7:26 pm
Remove the plastic kick panels - a single phillips screw on the drivers' side, same screw plus two x 8mm hex screws for the bonnet release lever on the px side.
danman2k
Wed Aug 06, 2008 7:28 pm
ok great, i will give it a shot. cheers :D i always have probs with interior lol never looks the same when i put it back on
Chris-W
Wed Aug 06, 2008 7:29 pm
Don;t forget to ease the door rubber away before trying to pull the panel away :thumb:
danman2k
Wed Aug 06, 2008 7:32 pm
ok cheers :D
danman2k
Wed Aug 06, 2008 7:53 pm
ok, got it all off. had a look and cut a LARGE red and black wire and a SMALL one. both going to the connecter and connected the the ends to maintain the loop. this has not help my problem. have i done this correctly?.
if yes, my problem is when i turn key on drivers door from open to lock, nothing happens apart from pin comes down a touch but does not lock.
also my darling daughter snapped the drivers inside door handle and was recently replaced, i think this has caused my problem. any help please good people
325i 88 err auto
swinster
Wed Aug 06, 2008 9:16 pm
Take a look here
http://www.e30zone.net/e30zonewiki/inde ... g_problems
It helped me with mine
swinster
Wed Aug 06, 2008 9:38 pm
danman2k
Wed Aug 06, 2008 10:22 pm
ok, will do cheers :D
danman2k
Thu Aug 07, 2008 1:41 pm
thanks for all the help, i have isolated the problem to the switch on the barrel. im not sure but the barrel or the switch is loose and its not obvious to me how i should proceed. if i push the switch closer/tighter all works for a couple of times but then nothing again. any help pls
Thu Aug 07, 2008 2:00 pm
danman2k wrote:my problem is when i turn key on drivers door from open to lock, nothing happens apart from pin comes down a touch but does not lock.
So what happens when you turn the key in any of the other locks? (Before and after your 'mod').
Omi
Witty custom rank.
Thu Aug 07, 2008 2:20 pm
I have the same issue... Check for wear on the L-shaped piece on the inboard end of the barrel, and the fork this sits in. ZimmerBimmer will do you a repair/replace kit for not a lot of coin if this is the cause.
...or is it?
danman2k
Thu Aug 07, 2008 3:01 pm
nothing if i remember properly, i did find out that one little key on my key ring was for the passenger side which i thought was for the boot,and the driver side key is no good on the passenger side.
i tried the mod but was no different, i then took out the ecu which had some corrosion on the pins, cleaned these up and put it back but still no different. we then reversed the mod incase i done it wrong, still no different, then took door panel off to see inside and we found the switch by barrel is loose.
i also tried the passenger door just now, i can open and close the lock but no central locking.
danman2k
Thu Aug 07, 2008 3:04 pm
Omi wrote:I have the same issue... Check for wear on the L-shaped piece on the inboard end of the barrel, and the fork this sits in. ZimmerBimmer will do you a repair/replace kit for not a lot of coin if this is the cause.
this is defo my problem, i just dont know how to fix it, we took it apart and it seems its not tight enough and keeps coming loose so having a poor contact with the switch. zimmer is away for awhile as i have been trying to get some other bits. we will look at your sugestion again and see where we are. :D
danman2k
Fri Aug 08, 2008 3:05 pm
all sorted, was able to fix this issue with brianmoores tips in earlier threads. thanks
here was the fix brianmoore had for this problem for anyone using search.
This can probably be sorted without any new parts. This is a standard procedure on any E30 that comes my way.
First of all, to improve access to the lock, unscrew the single bolt that holds the bottom of the window glass guide in place, pull the metal part down a bit, and it will unclip just below glass level. You can then swing the bottom of the guide up out the way towards the middle of the door.
When you get it out, first make sure the swivelling bit with the over centre action on the back end of the key barrel is all working freely and is well greased, then slide the bracket for the dead lock microswitch into place on the key barrel and bend the middle of the microswitch arm very slightly to take up 15 years of wear, and get that part working properly.
If you look at the alloy arm on the back of the key barrel you will see it is worn by contact with the steel fork it engages with on the door catch.
Bend this steel fork slightly so that it engages with an unworn part of the alloy arm, grease everything, and reassemble.
Your driver's door lock should now work as new.
If the unlock/lock is still a bit hit and miss, then try adjusting the lock motor a little in its slotted holes.
