removal of high beam light. mot?
Thews
Mon Jul 14, 2008 8:30 pm
Hi all,
Im thinking of taking out one of the high beam lights (the one closest to the kidney grill) to put in a custom air feed for my filter. does anyone know where you stand as far as mot is concerned? do you need to disconnect the other one ect?
cheers
monkey
Mon Jul 14, 2008 8:36 pm
could you not use a pair of mk 1 or 2 golf round headlights as they have dip and main beam in one lamp . you could then leave the spare main beam lamp in but disconected and sill have working lights
Thews
Mon Jul 14, 2008 8:38 pm
thats a top idea, thanks
bodger
Mon Jul 14, 2008 8:43 pm
sorry to butt in but i was thinking could the dipped headlight (smiley one) be used in the high beam place so all 4 lights would be on instead of just the outer ones when driving normally at night, would be easy to make smoked light without one off them cross things too, i could use my old non smiley projectors so not to have 4 smileys too, obviously this would have to be reversed come mot time winkeye
Mon Jul 14, 2008 9:00 pm
Lights have to be symmetrical.
hennabm
Mon Jul 14, 2008 9:04 pm
There has to be 2 main beams and two dip beams, ie one each side. Whether that is in one lamp or two, there has to be one type of beam each per side.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
monkey
Mon Jul 14, 2008 9:35 pm
there would be 2 mains and 2 dips if you used two golf lights in place of the dip lights and you would then be free to remove one main unit for an air intake and just leave the remaining main beam one where it is but not conected . dont know how well they would fit though
agent006
Mon Jul 14, 2008 9:39 pm
Mine failed on missing left main beam light at last MOT.
monkey
Mon Jul 14, 2008 9:41 pm
i guess you had two dips and one main .
Mon Jul 14, 2008 10:33 pm
There has to be a matching, working pair of both main and dipped beams, with the dipped beams correctly aimed.
Each main and dipped beam can be combined into a single unit.
murran
Mon Jul 14, 2008 11:27 pm
what mr mooore said^^^^^
http://www.motuk.co.uk/manual_120.htm
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
maxlee
Tue Jul 15, 2008 2:24 am
are the golf lights a easy fit???
