Should i buy a 318is?
dimebag_from_hell
Mon May 05, 2008 9:16 pm
I'm considering looking for a 318is ebay bargin.....how much can you get a clinker for? Do they come up often?
do they come with an LSD? What are the engines like, can they take abuse?
cheers
neilofla
Mon May 05, 2008 9:33 pm
how much is anything from 100 nicker to 2 grand
No LSD as standard, but you might be lucky. either way it'll prob be a small case diff, they get whiney and loose in old age
engines are fairly peaky compared to a 325, but are very strong and if they've been given regular oil changes it'll sit on the rev limiter all day long. (if you're into that type of thing)
Bob_S
Mon May 05, 2008 9:43 pm
great cars for hounding the small diff's cope fine with the power and age it's only when you put silly power through them they cant cope, look after it and it will see you fit.. there is or was a lovely silver one on PH for 1300 squid looks very proper.
Bollocks to this 24v scrap!
Stifla
Mon May 05, 2008 10:13 pm
neilofla wrote:No LSD as standard
I thought lsd's where an option on the is?
neilofla
Mon May 05, 2008 10:48 pm
Aye. not standard, as in not fitted as standard. only fitted as an optional extra.
Bob_S, did sell that iS in your sig to an irish guy? (The reg plate is distinctive) if you did you kept it in great nick, theres pics of it up on an Irish e30 site.
anywayback on track:
dimebag have a gander at http://www.carandclassic.co.uk/car/C43824
maybe this is the same one Bob_S saw but on a different site.
dimebag_from_hell
Wed May 07, 2008 7:53 am
I quite like the look of that, what mpg can you get from a 318? Much hassle fitting a LSD?
cheers
pnd
Wed May 07, 2008 9:26 am
engines are fairly peaky compared to a 325, but are very strong and if they've been given regular oil changes it'll sit on the rev limiter all day long. (if you're into that type of thing)[/quote]
i wouldn't say these engines are strong they were notorious for being fragile years ago although a well kept example should be ok.
jaistanley
Wed May 07, 2008 9:56 am
Fragile? I thought they were notorious for profile gasket leak, not for going pop?
Andyboy
Alpina Colada
Wed May 07, 2008 10:09 am
That looks like Andy P's old car.
neilofla
Wed May 07, 2008 12:31 pm
about 25mpg ragging it to 35mpg on a run.
an LSD should't be too much trouble to fit, and a medium case diff, from a 325 for example, should go in without much difficulty.
Dipesh
Wed May 07, 2008 10:21 pm
neilofla wrote:Aye. not standard, as in not fitted as standard. only fitted as an optional extra.
If the last 3 digits of that car are XNM then its my grandad's old car. That chrome gear stick is what i put on it, if it is his old one that is!
320i Convertible
trevski
Wed May 07, 2008 10:24 pm
nothing like the sound of a six pot mate :P winkeye winkeye winkeye
Bob_S
Wed May 07, 2008 11:14 pm
Yeah I did sell it - regret-ably :( and it probably is the one you've seen, thanks for your comments :)
Yeah thats the IS I was on about it looks like a decent one
Alburglar
Thu May 08, 2008 12:07 am
How can you tell if a small case diff is LSD version?
M42 - rightness! with proper 4.27 LSD
Steve-E30
East Sussex Hooligan
Thu May 08, 2008 12:26 am
Thats had a drivers door hasnt it ??
Few of the pics the door looks out of line and a slight different shade .
Giggety Giggety Goo!!!
neilofla
Thu May 08, 2008 12:50 am
I think the diffs have the ratio printed on them, or on a tag attached to it, look for an S printed beside the ratio number, indicating its a lsd.
fairly likely theres dirt/corrosion in the way though, so you can check by jacking up both rear wheels at the same time, and turn one wheel forward, if the other wheel turns the same way its an lsd. if it turns the the opposite way its an open diff
I think the small case lsd is rare enough though
Pal318is
Thu May 08, 2008 9:05 am
I'll keep the answer to your question simple - Yes you should buy one. Great Cars. Mine took plenty of abuse, nothing excessive, but it sat on the red line, many a time quite comfortably :cool: even at 215k....
Pal
Pal
Image[img]http://Image
ric325i
Thu May 08, 2008 1:14 pm
neilofla wrote:fairly likely theres dirt/corrosion in the way though, so you can check by jacking up both rear wheels at the same time, and turn one wheel forward, if the other wheel turns the same way its an lsd. if it turns the the opposite way its an open diff
not always the best way as an open diff can spin the same way :mad: butits a good rule of thumb.
neilofla wrote:I think the small case lsd is rare enough though
na you can find them and get them MUCH cheaper than the larger case difs! looking at about £150 for a small case LSD.
perfect for short blasts :twisted: poor on the motorway :evil:
Bob_S
Thu May 08, 2008 1:36 pm
wrong small case diffs seem to command more as all the 4 pot wrong-uns want them
Kedge
Thu May 08, 2008 2:00 pm
I wish, more like nearer £300-400 for a small case LSD.
Instagram - Kedge85
Gwynleym10
Thu May 08, 2008 10:03 pm
I have bought two sub £400 IS's both were good cars, one was under 100k other was over 200k - hard to tell the difference really.
Great cars, good on fuel - can get close to 40mpg if you keep it serviced. I think they are better than 316/318i for this.
London 2 Cape Town
www.Overlandinthesun.com
