Renewing / updating all the bushes...?
OBs
Mon Apr 14, 2008 12:16 pm
Ive tried the 'search button' but no joy :?
Can anyone please point me in the direction of a thread listing all the bushes that need replacing and with the other options i.e M3 eccentric bushes etc
OBs
gIzzE
Mon Apr 14, 2008 12:37 pm
+1
This should be a sticky too imho, so many people spend loads on upgraded suspension when their car has bushes that are shot to buggery.
I had a CSL before this and it was pretty much accepted that after 2 years and 15k miles the rear trailing arm bushes and maybe the top mounts should be replaced, I bet most of the cars on here are still using most of the original bushes that are around 20 years old!!
A list of OEM part numbers would be great.
And a list of alternatives, including things like E46 M3 top mounts etc.
abelai
Mon Apr 14, 2008 12:57 pm
If I can't fix it I'll f**k it up so bad nobody can!!
d6dph
Mon Apr 14, 2008 1:00 pm
We are always looking for articles to add to the forum, So if someone wants to do a comprehensive list of these sort of things feel free :D
OBs
Mon Apr 14, 2008 2:23 pm
Front.
Pair of E30 M3 eccentric top strut mounts (31331139484) £94.41 each
studs x6 (31331092886) £3.56 for 6
nuts x6 (31331092887) £0.95 for 6
Pair of E30 M3 eccentric lollypop bushes (31 12 9 061 222) £20.00
Pair of E30 M3 ARB drop links £52.76 pair
Pair of front ARB bushes £18.55 pair
Nuts, bolts & washers to suit the ARB mounts & drop links extra £5 per link.
Rear.
Pair of E46 M3 cab top shock mounts 33.29 pair
Pair of E30 rear beam bushes £52.39 pair
Set of trailing arm bushes £25.74 per side
Pair of ARB bushes £5.68 pair
Pair of ARB drop links £20.62 pair
Nuts, bolts & washers to suit the ARB mounts & drop links, trailing arms and rear beam Extra £8 per side
3.0 / ZM3 Differential mounting bush (33 17 2228 425) - £21.34
All available off Paul at >>Zimmerbimmer parts department<<
OBs
xedman
Mon Apr 14, 2008 2:32 pm
engine mounts
gearbox mounts
front top mounts
rear top mounts - E46 M3 cab ones
Subframe Bushes
rear trailing arm bushes, eccentric ones reduce negative camber on lowered cars - need 4
Propshaft Donut - centre propshaft bearing is also worth changing while your there
Bush on the diff back plate - ZM3 coupe one, fits and much stronger than normal E30 ones
OBs
Mon Apr 14, 2008 3:10 pm
Cheers for the reply, but Ive since then found the above and edited my post :D
Including some part numbers and prices, all available off Paul at
OBs
