Do i really have to take it off to change the filter or is there any tricks to get around this?
BTB2 6branch and oil filter
Just wondering, i was about to change the oil and forgot that the BTB manifold was kinda in the way of the oil filter.
reverse the oil filter housing 180 degrees. Swop the oil cooler pipes round, this will reverse the flow but it will work fine. Then you can get to the oil filter for future changes.
Yes you must change it, no point putting new oil in really if you don't
You can do it with the exhaust on - I unscrewed the filter and with a bucket under it passed it between the manifold and the end of the part that attaches to the filter (which has the oil cooler feeds off of it). Spilt a little oil into the bucket but easier than removing the manifold by a long shot
Ok, i'm gonna look into that, thanks.Dunx wrote:You can do it with the exhaust on - I unscrewed the filter and with a bucket under it passed it between the manifold and the end of the part that attaches to the filter (which has the oil cooler feeds off of it). Spilt a little oil into the bucket but easier than removing the manifold by a long shot
Templ8e30
The BTB is a good manifold but this is one of the drawbacks.
The other one is zero access to the block coolant drain plug, feckin impossible to get to
I tried the 180 degree trick on my old e30 and it worked fine, unfortunately the aircon compressor is in the way on this one. Filter strap is the tool of choice now.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Iain i've had this problem you can point it to the floor instead. But you will have to lose the bracket which holds the cooler pipes to the front panel. Otherwise they won't sretch far enough and they cross thread easily as the filter housing is ally. As i have found out in the past!
Templ8e30
Nice one Simon, shame I read this post after just finishing my 2.8 installSimon13 wrote:Iain i've had this problem you can point it to the floor instead. But you will have to lose the bracket which holds the cooler pipes to the front panel. Otherwise they won't sretch far enough and they cross thread easily as the filter housing is ally. As i have found out in the past!
Cheers,
Iain T
