can you pm me your address?
can i post the whole car to you for you to return finished?!!!
I was thinking thatDanThe wrote:Have you been on a diet Gareth? Bleach dipped the ginger also? Or have you just had enough of women
i have been on a diet, i have had enough of the women i know and i have bleached my hair..... all is revealed below!!!!DanThe wrote:Have you been on a diet Gareth? Bleach dipped the ginger also? Or have you just had enough of women
Glad its not just me being pathetic! The 6mm pipe in comparison is much easier!gareth wrote:The worst part was indeed going up through the vent and into the centre of the tank and onto the valve, what an arse!!!!
There's a hard way and an easy way of doing most things! This was the hard way!StuBeeDoo wrote:That was my biggest 'mare with the LPG install too.gareth wrote: the worst part was indeed going up through the vent and into the centre of the tank and onto the valve, what an arse!!!!![]()
Don't tell anyone, but a Ford one is what's on mine at the moment.stonesie wrote:Can i use a Ford/Bosch 4 wire lambda off my escort (removed thanks to a code reader but turned out to be fine, so its going spare at the moment)
E30 wheel well will take 630mm max, and this one's 600mm.gareth wrote:if the tank fits in the wheel well you're in business!
Not the worlds biggest bargain, but not ridiculous, I suppose. Just over £100 is what I would aim at, plus carriage.stonesie wrote:Probably not perfect but i can loose an inch or 2 of boot depth with no worries, there's a seller on there selling new leonardo's for £150 deliverd.... Is that a good price or should i keep looking?
http://cgi.ebay.co.uk/LPG-Leonardo-Mill ... 18Q2el1247
Anything slightly more modern than steam powered . Runs on Windows95 perfectly.I don't own a laptop so thats another thing on the shopping list, what kind of spec do i need to map a leonardo?
