i need to empty my tank as it's shot but i have no drain plug
i think i'll just use the pump to do it however, in the absence of my manual..... which is the fuel pump relay and which pins do i need to connect?
ta in advance
i'll have a look aand see if i have a spare plug lurking, otherwise, i just need to drop the underdash panel down to get to the relay so it's not that bad...
You can always bridge fuses 11 and 24, 25, 26, 27 or 28 in the fusebox. Just push the bare ends of a piece of wire into the top of the fuses to touch the wire.
