Page 1 of 2
Interior light delay with auto dimming.
Posted: Sun Oct 28, 2007 6:24 am
by georgegraves
I am proud to introduce to you the newest mod for our e30's.
Automatic interior light delay dimming - the "g-light"
http://www.digitalunderpants.com/dim/demo.mp4
(Youtube version here: http://www.youtube.com/watch?v=xjPSJVDmgaU)
It works just like newer BMW's, when you close your driver's door, it keeps the the lights on, and then slowly fades out over a period of about 30-45 seconds(these units are no longer adjustable)
It has an added feature that when you turn the key, it dims down the light quicker, so that you can start driving. Anyone that had driven a newer BMW knows this feature. It adds a really cool lighting effect, and is very useful at times. Like when you need to read a map real quick.
- Quality construction
- PWM (pulse width modulation) design uses very little current, less then the stock relay
- Custom printed circuit board.
- Replaces stock relay
- No cutting, no splicing
- Installation only requires a Phillips head screw driver and a 8mm socket.
- Free USPS priority shipping(USA only)
- Bench tested to over 50,000 cycles with out failure, about 6+ years of normal use
EDIT: Note that the delay featured is only triggered by the drivers side door - opening the passenger side door simply switches the light on and off, handy if you're like me, and always getting something out of the car. All the original functions of the interior lights remain. You can still manually switch them to the "always on" or "always off" position as well.
Here is a look "under the hood"
Final price shipped with no insurance/tracking: £Â£ 19.22 GBP
Final price shipped fully insured: £Â£ 28.95 GBP
I'm offer the shipping with out tracking and insurance as an option, but if it got lost in the mail, you would be out of luck - I won't be able to replace it. It would be too easy for someone just to say that they didn't receive it.
01 - ryno
02 -
03 -
04 -
05 -
- remove the drivers side bottem dash cover to gain access to the hood relase cable bolts (8mm) and remove the bolts.
- Remove the speaker panel and the speaker.
- Remove the two screws that is just below the speaker opening and reach into the speaker cavity and pull the bracket out
- Remove relay, and plug in the new dimmer mod.
- button it back up and you are done.
QUESTION: How do I check to see if I have the stock relay?
ANSWER: Don't worry, you don't have to take anything apart.
Simply open your drive's door, kneel down, and slowly and
gently push in the black pin in your door jam (it's on the car not the
door), you should see your interior light go out when you do. Now do
it a few more times slowly, and listen for a clicking sound
coming from about where the speaker is. If you hear a click, you
have a relay and are good to go.
QUESTION: "Does it require no extra modification for it to dim
down quick when you turn the key or do we have to tap into the
ignition switch?"
ANSWER: No extra
work, it is plug and play. remove the stock relay, and replace with
this. ZERO cutting, ZERO splicing...
QUESTION: Where exactly is the relay that it replaces?
ANSWER: The stock relay is located below the speaker on the
driver side foot well. Basically, you remove the kick panel, and then
pull the speaker out, undo two screws holding the relay bracket
and pull the bracket out from under the speaker cavity, replace
the relay, and you are done.
QUESTION: What happens if you have non-stock speakers with
bigger magnets, could there be a clearance issue?
ANSWER: Not
a prolbem - The relay is *below* the speakers, not behind it.
QUESTION: I have led's in my interior light sockets. Would the
dimming function work with these lights?
ANSWER: I have not tested LED's yet
QUESTION: What happens if I don't have the stock relay, will
this still work?
ANSWER: Yes, you will need to splice two wires to make it work, when you paypal me request the non-stock relay version.
BEFORE INSTALLING THIS PRODUCT YOU MUST AGREE TO THE FOLLOWING CONDITIONS: 1. YOU AGREE TO BE FULLY RESPONSIBLE FOR ANY MISTAKES, ERRORS, MATERIAL LOSS, PERSONAL DAMAGE, SECONDARY DAMAGES, CAUSED BY ANY CIRCUMSTANCES RELATING TO THE USE OF THIS PRODUCT. 3. YOU ACCEPT FULL LIABILITY FOR THE OPERATION AND USE OF THIS PRODUCT AND ANY VEHICLE HAS BEEN INSTALLED ON. THE ONUS IS ON YOU TO CAUTION OTHERS WHO MAY OPERATE THE ABOVE VECHILE. 4. AGREE TO COMPENSATE GEORGE GRAVES FOR ANY LOSSES DUE TO LEGAL ACTION BROUGHT AGAINST ME BY YOU AND OR ANY OTHERS WHO HAVE OPERATED YOUR VEHICLE FOR ANY REASON. 5. ALL DRAWINGS, PICTURES, DESIGNS, ARE COPY WRITTEN AND ARE THE INTELLECTUAL PROPERTY OF GEORGE GRAVES AND ARE NOT TO BE REPRODUCED. 6. NO WARRANTY OR GUARANTEES EXPRESS OR IMPLIED.
Thanks you all, and I hope you enjoy!
George Graves
Re: Interior light delay with auto dimming.
Posted: Sun Oct 28, 2007 3:46 pm
by daimlerman
What is your best price for two units,priced in UK pounds,please?
Posted: Mon Oct 29, 2007 1:52 am
by georgegraves
For two units - at $39.50 x 2 + $20 shipping w/ insurance = $99 USD or £Â£48.18 GBP
Since you are ordering 2, I'll give you a 10% discount, your price for two units shipped to your door is £Â£43.37 GBP
You can paypal me at george.graves@gmail.com - either in GBP or USD (43.37 GBP = 89.1247 USD)
As long as the amount I recieve is about $90 USD I'm fine with that.
Here is the currency calculator I used to convert - http://www.xe.com/ucc/
Posted: Mon Oct 29, 2007 3:14 pm
by Steviec
If there are several people who want these, we could get them sent to my work as one package (im guessing this would save quite a bit on postage) and I could forward them on from my work to people, free of charge.
Just thinking of a way to save people a few extra quid!
Posted: Tue Oct 30, 2007 3:12 pm
by daimlerman
Hi George,Thanks for your quote,I am certainly interested at that price.Now in your article you mention a relay that clicks when the door switch is operated.On both my E30's when I operate the pin switch in the R/H door(drivers) I can hear a relay clicking somewhere in the L/H footwell.You mention that this dimming only works from the drivers door.As my drivers doors are on the R/H side,will it still work properly?You mention fitting in the L/H speaker panel area,by the central locking relay,on my cars the central locking relay is mounted on the drivers(R/H) side.I am pretty fair with spanners but not to confident with the electrical issues!!
Posted: Tue Oct 30, 2007 3:35 pm
by grantfk10
I am assuming that the installation instructions above are written for Left Hand drive E30s. Will it work on the drivers side door on Right Hand drive?
Posted: Tue Oct 30, 2007 4:12 pm
by A1BMW325iSport
poss also interested in one, thanks
Posted: Tue Oct 30, 2007 10:53 pm
by georgegraves
daimlerman wrote: I can hear a relay clicking somewhere in the L/H footwell.
Really? Since it would be a preaty long boat ride to come look at a right hand drive e30 - I'll have to get some help from you all.
I found this -
Here: http://mysite.wanadoo-members.co.uk/smi ... itting.htm
Now, as I'm looking at that picture - that IS the Right hand/drivers side.
Regardless - don't worry about the electrical - If you have the relay installed from the factory (where ever it is located) you just replace it. If you are missing the relay, you will need to connect the two wires as described on the page above or here: http://www.e30zone.net/modules.php?name ... rior+light
Posted: Tue Oct 30, 2007 10:56 pm
by 6-Shooter
I'll take one - what do I do?
Posted: Tue Oct 30, 2007 11:25 pm
by grantfk10
Yip, that is the right hand/drivers door. This is where my central locking relay is.Does your unit just plug in?
Is there a discount for a group buy?
Posted: Tue Oct 30, 2007 11:29 pm
by georgegraves
6-Shooter wrote:I'll take one - what do I do?
You have a PM.
Posted: Tue Oct 30, 2007 11:37 pm
by georgegraves
grantfk10 wrote:Yip, that is the right hand/drivers door. This is where my central locking relay is.Does your unit just plug in?
YES, it just plugs right in - you would only need to splice two wires if you car was missing a relay from the factory. There are instruction above how to do that. See the link - 95% of cars have them from the factory BTW. You can test for it -
Simply open your door, kneel down, and slowly and
That is the discount price - kinda. I find formal "group buys" to really be annoying, you have to wait weeks while the list fills up, only to save a few bucks. If you order 2, I'll give you a 10% discount - so go find a friend, just please don't plan out an entire "hey, who want to go in on two of these" kinda of posts here - please keep it to friends/locals.
Posted: Wed Oct 31, 2007 12:56 am
by Brianmoooore
The central locking locking loom with the 'relay' mounting plate is reversed in RH drive cars compared to LH drive cars.
If you want to get it to work on both front doors, then you have to run a single wire from one side of the car to the other.
George - very, very few E30s have a delay unit fitted from the factory, so very few have the door handle switch.
Posted: Wed Oct 31, 2007 1:38 am
by georgegraves
Oh - well I see - most cars in the state have them, but the relay or the door switch fail after a few years.
My unit does not need or use the door handle switch to trigger the lights, only the door pin switch.
Posted: Wed Oct 31, 2007 9:03 am
by 6-Shooter
Brianmoooore wrote:The central locking locking loom with the 'relay' mounting plate is reversed in RH drive cars compared to LH drive cars.
Where would you wire the switch upto?
George - you have your next project!
Posted: Wed Oct 31, 2007 9:04 am
by 6-Shooter
One more thing, I fitted a delay relay but it does not work. Your unit replaces this right and just plugs right into the loom for it?
Posted: Wed Oct 31, 2007 10:25 am
by Brianmoooore
6-Shooter wrote:One more thing, I fitted a delay relay but it does not work. Your unit replaces this right and just plugs right into the loom for it?
You have to disconnect a wire from one connector and connect it to another. Also, if you don't have the door handle switch, the wire from that will need to be spliced to that from the door pin.
Posted: Wed Oct 31, 2007 10:27 am
by Brianmoooore
6-Shooter wrote:Where would you wire the switch upto?
Disconnect the existing wire from the passenger pin switch, and run a new wire from here to the wire from the driver's door pin switch.
Posted: Wed Oct 31, 2007 2:45 pm
by daimlerman
George,just sent paypal for two units.... winkeye
Posted: Thu Nov 01, 2007 1:00 am
by Onz
have you tested it with led's yet? and how many regular lights can it handle?
Posted: Thu Nov 01, 2007 9:51 pm
by M5pilot
This is quite a cool product!
Posted: Thu Nov 01, 2007 10:58 pm
by georgegraves
daimlerman wrote:George,just sent paypal for two units.... winkeye
Got the funds - thanks, should ship out today or tomorrow.
Onz wrote:have you tested it with led's yet? and how many regular lights can it handle?
I keep meaning to buy some ebay LED bulbs to test with, it *should* work with LED as my unit uses pulse width modulation. I try to pick some up for testing.
I tested it up to about 45 watts of lighting with out a problem. WAY more light than you would ever want in your car.
Posted: Fri Nov 02, 2007 9:29 am
by slinky2000
I'm lost, its not just plug and play on a normal e30? shoudl you need one unit or two? or as brian says? one unit and run a wire to the passenger door?
Posted: Fri Nov 02, 2007 8:19 pm
by Brianmoooore
IF you already have a factory fitted delay unit in your E30, then this unit is P&P.
If you don't have a delay already, then you will have a socket to plug it into near the locking ECU underneath the driver's footwell speaker.
To use George's unit, you have to do exactly the same as you would do to fit an OE BMW unit: Pull the wire off the driver's door pin switch, and plug it into a spare socket nearby, find a spare wire taped to the loom, untie it, and plug it onto the door pin switch.
The factory fitted unit also has a switch which is operated by the outside driver's door handle. Since you almost certainly won't be fitting this, the pin on the delay unit that connects to it has to be connected to pin from the door pin switch instead (i.e. link two connections on the delay unit together).
The factory unit only operates from the driver's door. If you want it to operate from the passenger door as well, then you have to remove the connector from the passenger door pin switch, connect a new wire to it, run the wire across the car, and connect it to the wire from the driver's door pin switch.
Posted: Sat Nov 03, 2007 12:08 am
by daimlerman
Thanks for the above,Brian,as soon as I receive my units I will fit one and report.
Posted: Tue Nov 06, 2007 10:29 am
by Onz
Anyone done an LED test yet?
Posted: Tue Nov 06, 2007 2:07 pm
by daimlerman
Has anyone received one of these units yet?I sent $90 by paypal on the 31st of Oct.,to the email address given, so far it sits unclaimed....
Posted: Tue Nov 06, 2007 6:48 pm
by SHAKEELE30
People im pretty sure you can get kits and do this yourself with a little bit of soldering! Save yourself the hassle. Have a look at the link below...
http://www.maplin.co.uk/Module.aspx?Mod ... t&doy=6m11
Re:
Posted: Tue Nov 06, 2007 10:59 pm
by sam325is
when i open and close my drivers door i hear a click from the passenger footwell from behind the speaker. does this mean i have it. also sometimes my interior lights have a delay but sometimes they dont it is inconsistant but intentional when it happens. i know this becuase when it does happen i can wait for it to go off open the door and do it again and it will work untill im blue in the face. but sometimes it doesnt work at all.
any ideas?
Posted: Tue Nov 06, 2007 11:07 pm
by FlappySocks
SHAKEELE30 wrote:People im pretty sure you can get kits and do this yourself with a little bit of soldering! Save yourself the hassle. Have a look at the link below...
They dont dim. Besides, if you can build them, why not build the one on mp3car.com
http://www.mp3car.com/vbulletin/hardwar ... delay.html
Re:
Posted: Sun Nov 11, 2007 10:24 pm
by sam325is
^^^ any ideas
Posted: Fri Nov 16, 2007 1:21 am
by georgegraves
daimlerman wrote:Has anyone received one of these units yet?I sent $90 by paypal on the 31st of Oct.,to the email address given, so far it sits unclaimed....
Sorry about that, I've been on vacation and there seems to be some kinda of paypal mix up on my end. I'll get back to you all as soon as I can track down the prolbem.
EDIT: I think you are tring to send it to the wrong paypal address - please check your PM.
Re:
Posted: Fri Nov 16, 2007 1:55 am
by georgegraves
sam325is wrote:when i open and close my drivers door i hear a click from the passenger footwell from behind the speaker. does this mean i have it. also sometimes my interior lights have a delay but sometimes they dont it is inconsistant but intentional when it happens. i know this becuase when it does happen i can wait for it to go off open the door and do it again and it will work untill im blue in the face. but sometimes it doesnt work at all.
any ideas?
One of two things fail with the stock relay. Either the door handle switch, or the relay it self.
My unit does not use the door handle switch, so even if your is faulty it would work regardless.
Re:
Posted: Thu Nov 22, 2007 7:33 am
by georgegraves
I have 3 units left.
Re:
Posted: Thu Nov 22, 2007 11:12 am
by sam325is
I will definatley have one from you so keep one for me.
