BMW E30- SUMP GUARDS (Group Buy)
Posted: Tue Jan 19, 2010 8:26 pm
by RPM
Protect your sump on lowered cars or for the track drivers that like the kerbs
RPM Sump Guards £75.00
Delivery £10.00
Designed to clear the deaper 318 sumps.
Manufactured from 3mm steel, and zinc plated.
We run these on a number of the PBMW race cars, this is a tried and tested product.
Fitting:
The sump guard picks up on existing holes on the front cross member behind the spoiler and the cross member that supports the engine mounts, there will be 3 holes to open out slightly.
The Kit will be complete with bolts and instructions.
I want to get a batch of 10 together, so please list you name and intent to buy below. If we fall short of the 10 I may put the balance into stock but there seems to be a lot of interest by looking at my PM box!
TO ORDER
If you are interested please add your name to the thread below:
http://www.e30zone.net/modules.php?name ... c&t=157793
Should you need any further help or advise please email us on info@raceperformancemodified.com
Posted: Wed Jan 20, 2010 4:34 pm
by Dan320is
Can the sump bung be accessed with the guard in place?
Re:
Posted: Wed Jan 20, 2010 6:02 pm
by penton08
will it fit over a s50 with a e34 sump?
Re:
Posted: Thu Jan 21, 2010 10:40 am
by Jhonno
penton08 wrote:will it fit over a s50 with a e34 sump?
Measure Nath.. :wink:
Re:
Posted: Thu Jan 21, 2010 11:27 am
by pac1982
You say these are designed to fit the deeper 318 sumps, does this include the 318IS?? i know the IS has a low sump just not sure if its any lower than a normal 318
Re:
Posted: Thu Jan 21, 2010 2:51 pm
by Dan320is
pac1982 wrote:You say these are designed to fit the deeper 318 sumps, does this include the 318IS?? i know the IS has a low sump just not sure if its any lower than a normal 318
318i and 318is share the same sumps as they have the same basic block.
Re:
Posted: Thu Jan 21, 2010 2:53 pm
by ImysE30
Will these fit for those who have M52 or M30 conversions?
Re:
Posted: Thu Jan 21, 2010 9:15 pm
by magpie
this is what i had fitted to my m40,good bit of kit that does the job well and easy to fit.
Posted: Fri Jan 22, 2010 11:02 pm
by mccarthy
Dan320is wrote:Can the sump bung be accessed with the guard in place?
would also like to know this?
edit: answer found in linked thread!
Re:
Posted: Sat Jan 23, 2010 12:26 am
by magpie
no.^ unless the new batch has been modified.
if you can do a simple oil change yourself.
this guard takes little time or effort to remove every 5kmiles or so.
Re:
Posted: Sun Jan 24, 2010 10:50 pm
by Asserti
I guess the normal plastic cover cannot be kept if you place the sumpguard?
Re:
Posted: Wed Feb 03, 2010 10:33 pm
by RPM
I should have stock of these this week so will put up payment details soon
Jimmy
Re:
Posted: Fri Feb 05, 2010 10:34 am
by RPM
I have 10 Sump guards is stock now
Please send a paypal payment of £85.00 to info@raceperformancemodified.com and they will be sent out to you
Jimmy
