(feeler) Big brake conversion
Posted: Mon Dec 01, 2008 11:20 am
by Phill172
I was a bit unsure of what area to put this in but as its a group buy....!
Right guys the amount of posts I read on the forum about what brakes to upgrade to etc etc....
Spoke to a company who do discs, i bought some for my clio sport ages ago, but basically long story short they can do 4 x 100 Audi TT discs (312mm x 24mm vented for around £108 inc vat....
Based on if i can get enough interest saying around 10 people? There is no limit to the amount of people for the group buy, but aslong as its above 10!
I would like to make this into a whole package, well discs and adaptors, But what i need to do first is to get ones myself, and sort adaptors for standerd calipers and also Brembos.
All i aim for is to make it a damn site cheaper then 300mm.de!
any thoughts/interest?
Re: Big brake conversion
Posted: Mon Dec 01, 2008 11:24 am
by DaveD
if you can do it for 15"wheels ...280mm.. as a package.. :D
Posted: Mon Dec 01, 2008 11:35 am
by Phill172
shouldnt be a problem, if i get the interest and get my head round the caliper brackets
Posted: Mon Dec 01, 2008 11:38 am
by Rik178m
What wheel sizes would the TT brakes fit/not fit?
Posted: Mon Dec 01, 2008 12:49 pm
by Phill172
defiently fit 17", unsure about 16's i may be able to squeeze them under my 16" compomotives but will have to find out....
Posted: Tue Dec 02, 2008 2:32 am
by Rik178m
If they fit under 16's which I have and am quite fond of then I'm game
Posted: Tue Dec 02, 2008 9:21 am
by DanThe
Phill172 wrote: they can do 4 x 100 Audi TT discs (312mm x 24mm vented for around £108 inc vat....
sounds expensive to me, who manufactures the disc?
Posted: Tue Dec 02, 2008 4:06 pm
by tomson
I might be interested in this as I will be in the market for a brake upgrade in the new year, depends on the cost....
Posted: Tue Dec 02, 2008 10:09 pm
by adil325i
im interested also - what options are there on caliper?
Posted: Wed Dec 03, 2008 9:27 am
by Phill172
The way im working on it is basically Im going to look into the 280mm set up first that saying really shouldnt take to long!
For a 280 set up, i believe, correct me if im wrong the Mazda 4 pots from a RX7 can be used....
Also have been told the 406 coupe/fiat coupe Brembos are all the same, and will accomendate the 312mm discs...
So thats basically what I am aiming to be able to provide disc and cailper adaptors so all you simply have to do is find the calipers
280mm set up, you can get discs for around £50
Posted: Sun Jan 04, 2009 1:15 pm
by Ant
312mm discs just fit under 16" Borbet B's and Alpina 7Js
the 280mm discs are from a golf G60 iirc.
I'd suggest the brembo 4 pots are a non starter though due to the sheer bulk of the things, 750 sliding single pots require a bit of surface grinding to fit and leave a 4mm gap between wheel and caliper with new pads and discs fitted, thats with wheels of the correct offset btw and no spacer required.
Posted: Sun Jan 04, 2009 1:24 pm
by Gunni
You can buy the Audi discs with all the bolt holes already from numerous suppliers.
Re: (feeler) Big brake conversion
Posted: Sun Jan 11, 2009 9:30 am
by dcoeinside
Phill172 wrote:I was a bit unsure of what area to put this in but as its a group buy....!
Hi,
this is the disc you speek about. But....... with 4x100 bolt circle, centerhole for e30 and PowerGroove. !!!
You can have it in:
312x25 / 4x100 or 5x120(no double circle)
300x25 / 4x100 or 5x120(no double circle)
Posted: Sun Jan 11, 2009 9:47 am
by Demlotcrew
^ Looks like a ATE Disk to me.
Just buy the brackets from 300mm.de which are TUV approved and get on with it!
Andrew
Posted: Mon Jan 12, 2009 6:14 pm
by Keg_gt
IM in on this if its still on i have the calipers just need the tt discs and adaptors.
Posted: Tue Jan 13, 2009 8:48 pm
by rhett325i
Hi,
You can have it in:
do you have a link to where those rotors can be purchased?
Posted: Thu Jan 29, 2009 5:36 pm
by Keg_gt
this still happening?
Posted: Tue Feb 03, 2009 6:47 pm
by frenchman
Hi,
You can have it in:
Interesting stuff!
I guess the man who is going to manufacturethe biggest kit for BBS 15" wheels would earn a lot of money!
Posted: Sat Feb 21, 2009 1:05 am
by Dave_M3
Hi,
You can have it in:
+ 1
Need to sort discs for my new brakes winkeye
Posted: Sat Feb 21, 2009 11:59 pm
by Bob_S
the 312 will fit under 16" hartge's too
I still think a pair of discs and machining is cheaper..
Posted: Wed Apr 29, 2009 12:08 am
by miniblob
Phill172 wrote:they can do 4 x 100 Audi TT discs (312mm x 24mm vented for around £108 inc vat....
Are they genuine audi discs???
I'm sure i've heard (from a reliable source i think, just can't remember who/where!) that the genuine discs are lighter than all the others available, that are 'the same'!!!!
I'm sure the genuine audi discs were more than that from a dealer when i checked last year!!!
If they are genuine, i might be interested in a few months!! Can't commit at the mo though!!
Posted: Wed Apr 29, 2009 1:40 am
by Dave_M3
Bob_S wrote:the 312 will fit under 16" hartge's too
They fit under some 15"s too :wink:
Posted: Fri May 01, 2009 1:49 am
by Bob_S
which ones as they are damn tight on 16's?!
Posted: Fri May 01, 2009 5:46 am
by Dave_M3
Saw a set of Revolutions on a track car for sale recently and it had Brembos and Audi dics but thinking back now I think they were only 300mm.
Posted: Mon Feb 15, 2010 12:36 am
by 325tourer
fiat coupe brembos wont fit on 15", 16" as standard have 3mm clearence between alloy and caliper. thats std alloys.
they are 305mm discs with 4x98mm.
ive a fiat coupe aswell as the 325i,2nd hand brembos fetch between £100-£150 and a refurb kit is about £40 for seals etc.
Posted: Sun Feb 21, 2010 12:25 am
by bene30jane
will they fit 17", the fiat brembo's? how much are the 312mm discs and adaptors?
