Because Racecar [Lots of pics :D]
Posted: Mon Feb 20, 2017 11:56 pm
Hi Guys,
So last year at around 140mph the bottom end went on my M20 and some lovely rod knock started. I limped home and pulled the oil drain plug and found lots of sparkly bits in the oil, Yay!
Here's a pic of the car before i blew it up:
So i pulled the lump and started searching for a donor, i wasn't too upset because it was the perfect excuse for an m50 swap.
Donor found!
Time to start tearing it to bits, sorry E36 fans
So after swearing and snaping lots of rusty bolts:
Thew this bit in the bin lol. What a shed, anyway the engine ran nice so...
Bought an engine stand and removed the sump to swap the oil pump and pickup.
This because i've read all the horror stories
525i sump that i had modified for future snail draining needs.
Picked this up for a good price
Then I started to look at my E30 and realised how unhappy I was with the condition of the body shell. It looked nice in pictures but was by no means up to the standard I wanted and as we all know e30’s are prone to a bit of rot.
So i decided to pull the trigger and acid dip the shell!
Dropping the shell off to get dipped
Oh yea, and then i kinda got delayed by this little project cause using my friends unit was becoming impractical.
So yea, got there in the end
Only problem is the shell got rained on, badly... so it has surface rust everywhere
Anyway crying over spilt milk just leaves you with.... erm... dead cats or something like that.
So, life goes on. Once all the repairs to the shell have been completed it will be getting dipped again and then painted.
Anyways! I missed going sideways so much i put this kit together:
See what i did there
And here we are at present day. I've found some mobile welders who are coming out this week to start repairing all the holes, fully seam weld, extend the cage to the front shock towers and reinforce the cage mounting points etc![/b]
Donor found!
