Sorry, missed this one earlier:
e301988325i wrote:I have no doubt many are readig this, with 99% of us learning and hence have little to add. I'm amazed how inefficient helical gear teeth are at full chat, based on your flywheel dyno figure being way too high!
Agreed, that figure was way too high for my gearbox, but probably realistic for helical gears. To drop a 100hp over a set of spur-gears is unlikely, especially when I could reach under the car (
after the dyno test) and touch the gearbox without burning myself. But yes, helical cut gears are renowned for their inefficiency due to the axial directed force that results in additional friction. I have no doubt that replacing the helical gears with spur gears on a road car would result in a substantial fuel saving. The noise would, however, be unbearable. I also have no doubt that the only way I was able to achieve the wheel figure that I did is because of reduced losses in the gearbox. The losses in the diff are, of course, still as before.
e301988325i wrote:Home designed gearbox. . . That's just bloody awesome!
Thanks Mate!
e301988325i wrote:I use bohler for a lot of material at work, specifically, hardenable M340, 22CR Duplex and 25Cr Super Duplex.
Good to know, I may have questions in the future. M340 was actually recommended to me for my gears provided I was prepared to go through the process of induction hardening the gear teeth after through hardening the bulk material. I was tempted to go this route, but eventually opted for case hardened M120. Although the M340 would have made better gears, the hardening process is too detailed for the locals.
