Miller WAR Turbo tuning package
Posted: Sun May 25, 2014 12:24 am
by ross_jsy
Just thinking out loud here, want to start collecting bits for the turbo conversion over summer and with an impending sale of my KTM it will free up some folding.
Looking through a few m5x based turbo builds I see a few people have used the Miller War chip with good success. Here's a link to the kit:
https://www.millerperformancecars.com/s ... s5x-detail
Seems very good value considering it comes with injectors. So what does everyone think? Anyone have any experience? I would prefer to go MAP based, but the kit has some benefits for me, namely the base tune as I am really going to struggle with getting the car anywhere for mapping due to my location.
Posted: Sun May 25, 2014 9:16 am
by Driftben
Had a little read and saw this
https://www.millerperformancecars.com/s ... m6x-detail
I too wouldn't mind knowing if this is any good also because that would save me a load of time and money.
Only flaw is I wouldn't mind doing away with the MAF and have a 3bar MAP sensor.
Sorry for the no help post ross
Re:
Posted: Sun May 25, 2014 9:23 am
by leeparkes
If you are just after a chip Ross there is these guys...
http://eurotuning.us/et/node/13
Re:
Posted: Sun May 25, 2014 12:29 pm
by ross_jsy
Will want a lot more power than that Lee, and the Miller set up is adjustable
Re:
Posted: Sun May 25, 2014 1:16 pm
by leeparkes
More than 18 psi?
Would you be better with some standalone you can self tune, iirc you can do that with Megasquirt.
Re:
Posted: Sun May 25, 2014 1:45 pm
by ross_jsy
Missed that bit, stopped reading at the 250whp part. Could be an option, but I think the Miller is user adjustable. If I was on the mainland I would be more inclined to go full standalone but lack of a tuner over here is a problem. Plus I have no idea how to wire in VEMS/Megasquirt
Re:
Posted: Sun May 25, 2014 1:51 pm
by maxfield
ross_jsy wrote:Missed that bit, stopped reading at the 250whp part. Could be an option, but I think the Miller is user adjustable. If I was on the mainland I would be more inclined to go full standalone but lack of a tuner over here is a problem. Plus I have no idea how to wire in VEMS/Megasquirt
No days cars can be remotely mapped...
You can email maps etc. I know a guy who remotely maps cars all over the world and he has got a very good reputation.
To get the best standalone is the only way.
Re:
Posted: Sun May 25, 2014 3:22 pm
by ross_jsy
How does that work? Dyno pulls are crazy expensive over here! Can they take love from the road?
Re:
Posted: Sun May 25, 2014 3:34 pm
by maxfield
You can map cars on the road, although not easy. Holding revs etc. But it's how the cars used, not on a dyno.
The guy I know was adjusting the map on a drag car in New Zealand. The car was doing a run, he would analyze the data. Tweek the map and he would email it for the next run.
Re:
Posted: Mon May 26, 2014 7:47 am
by AndyR1001
Hi how's it going, I did a bits reading and went for the miller war chip and injectors. Not got it on car as yet as still collecting parts for build.
The war chip is essentially a fully mappable ecu much like mega squirt.
It is very popular in the states. What attracted me was just swopping out the old chip within ecu, a USB port is plugged into chip and pops out of side of casing so you can plug in laptop for tuning. Saves a heap of wiring using the standard loom!!
Miller will also send you maps and tweak a map for you if you send them the data.
Re:
Posted: Mon May 26, 2014 6:59 pm
by ross_jsy
I emailed them asking about compatibility and it won't work with a non Vanos as apparently the electronics are non upgradable. It would need to be converted to a TU loom.
What's the score with standalone? I'm fairly inept when it comes to electronics, is wiring one in simple?
Re:
Posted: Mon May 26, 2014 7:22 pm
by Speedtouch
See Flappysocks' site, www.diyefi.co.uk
Re:
Posted: Mon May 26, 2014 7:28 pm
by ross_jsy
M50'd innit :(
Forgot to say, your chip arrived nice and fast, cheers Maurice
Re:
Posted: Tue May 27, 2014 2:46 pm
by AndyR1001
adaptronic do a nice unit - efi-parts.co.uk - speak to Chris
Re:
Posted: Tue May 27, 2014 4:57 pm
by Speedtouch
ross_jsy wrote:M50'd innit :(
That's good to hear - thanks for letting me know. :)
Re:
Posted: Tue May 27, 2014 5:37 pm
by Demlotcrew
Problem with Map only is the low RPM drivability and response, simply the commercially available MAP sensors are not sensitive enough at low pressures.
You would have to run MAF/MAP or AlphaN/MAP.
I really like the look of the Miller WAR chip, what a great idea and I have considered it a few times, how ever, I really would like a little more sophistication, CAN, Knock Control, Data logging etc.
Re:
Posted: Wed May 28, 2014 12:36 am
by ross_jsy
It seems like a good solution that meets my needs.
Anyone know what is needed to convert to a TU loom?
Re:
Posted: Wed May 28, 2014 2:21 pm
by ross_jsy
In case it interests anyone, I emailed Megasquirt about the possibility of a plug and play kit for 88 pin motronic and it's something they are looking into but are having problems finding a case large enough to house the connector
Re:
Posted: Wed May 28, 2014 6:56 pm
by ross_jsy
Just stumbled upon this, not sure how I haven't found it before now. Like the idea of VEMS, seems very well priced for what you get and Craig seems to have had really good results:
https://shop.vems.hu/catalog/vems-motronic88-p-187.html
Have sent an inquiry
Re:
Posted: Tue Jul 01, 2014 1:04 pm
by ross_jsy
I've joined bimmerforums as they have a good boosted section and this has been recommended:
http://www.rktunes.com/tunes/m5x-s5x-obd-i-turbo-tune
While I don't really want a MAF based system, since I am having problems finding a way of mapping the car it might be an option
Re:
Posted: Mon Jul 07, 2014 4:05 pm
by craigieeb
Vems :)
Re:
Posted: Mon Jul 07, 2014 5:20 pm
by ross_jsy
Yep it is the only way to do it! It's part of what I need to speak to Gunni about.
The Americans seem quite opposed to using standalone it seems
Re:
Posted: Tue Nov 04, 2014 10:02 am
by BigJoe
Hello mate, I've got the miller war chop on my e30 b35 supercharged.
Did you managed to get yours sorted.
Re:
Posted: Tue Nov 04, 2014 8:26 pm
by ross_jsy
I've decided to go down the route of standalone, probably VEMS. But life has got in the way, have an engine to build and zero hours due to the start of a fairly tough degree.
Going to try and get a load done over the Christmas break providing my revision timetable isn't too full on. How do the youth manage uni and busy drinking lives?!
Re:
Posted: Tue Nov 04, 2014 10:51 pm
by BigJoe
I'm going to stick with the Miller setup as i have the 24lb injectors, war chip and maf. I know the feeling of not having the time.
I wish I went to uni when I was younger. Lol
My goal is to get mine perfect for next summer. Let's see.
Re:
Posted: Wed Nov 05, 2014 7:22 pm
by ross2009
joe your gonna have to make your profile pic smaller mate its taking up to much screen :)
