non vanos or vanos?
Posted: Wed Mar 20, 2013 7:25 am
by moggie
im going to start getting bits together for my turbo project and am unsure which engine to get,im loooking for 450hp and to what i can work out i will be going m50b25 hx35 turbo,vems management,im going to start building the engine now ready to swap next winter [so i can get to some meets this summer in the sport with standard engine] so does it matter if i get a vanos engine out of an e36 or am i better with the rarer non vanos engine?
Re: non vanos or vanos?
Posted: Wed Mar 20, 2013 7:17 pm
by Gunni
it won´t matter, both will make it to 450hp easily enough.
Posted: Wed Mar 20, 2013 8:35 pm
by moggie
do you still get the plug and play vems management gunni and were is best to get arp bolts and head gasket
Posted: Thu Mar 21, 2013 7:17 am
by moggie
also is there any benefits of using the m50 over my m20b25 engine i already have in?
Posted: Thu Mar 21, 2013 8:26 am
by ross_jsy
Easier to make more power
Posted: Thu Mar 21, 2013 6:26 pm
by moggie
more power is always good m50 turbo it is then!
Posted: Thu Mar 21, 2013 8:11 pm
by Gunni
Both engines will make 450hp if you give the old M20 enough boost that is.
should be about 1.6-1.7bar boost on a HX35.
There are no M20 PnP VEMS ecu´s, but I can get you a regular vems ecu,.
Posted: Thu Mar 21, 2013 9:43 pm
by moggie
im going m52b28 i think, is there a pnp vems for this engine?
Posted: Sat Mar 23, 2013 9:31 am
by Gunni
There is not.
I haven´t gotten enough free time to totally complete them.
Posted: Sat Mar 23, 2013 1:38 pm
by moggie
ok mate,i will give you a shout when im ready for purchase if thats ok
Posted: Thu Mar 28, 2013 9:50 pm
by makman
moogie where in west yorkshire are you? im based in Wakefield...got an m50 in mine myself but no turbs! drop me a pm if you ever need a hand...im good with the spanners aha
Posted: Fri May 10, 2013 5:01 pm
by sunnysr
this was my next question ,so with the vanos is it just the same to map etc ,im planning on just buying the full e36 car and taking the engine out so if its easier to map etc a none vanos i will just get a early one probably cheaper ,also on a side note how come people dont seem to turbo the e36`s is it a matter of space
Posted: Fri May 10, 2013 6:24 pm
by Gunni
It is a matter of space and cost basically., Mostly space
