Best way to flush engine oil after water contamination
Posted: Sat Sep 23, 2017 11:14 am
by Avinit4
Hello people, following hole in Head causing water to go straight into engine, can anyone recommend best way to do engine flush please? Thanks
Re: Best way to flush engine oil after water contamination
Posted: Sat Sep 23, 2017 1:20 pm
by Brianmoooore
Cheap supermarket oil for a few miles, repeat, fill with correct oil.
Posted: Sat Sep 23, 2017 1:39 pm
by Avinit4
Would running engine on idle for 5 mins be enough, or do I need to drive it. Also am I correct to think you don't think I should add any type of flushing agent as well?
Posted: Sat Sep 23, 2017 1:42 pm
by Avinit4
Is it Any spec for cheap oil or should it be 10/30 or something else? Thanks btw
Posted: Sat Sep 23, 2017 4:29 pm
by Speedtouch
Pretty much any multigrade will do. Best to change the filter when you put your good oil in.
Posted: Mon Sep 25, 2017 2:58 pm
by Avinit4
Because engine very contaminated with sludge I'm going to use cheap oil and flushing agent.. And yes will also change filter with final oil
