e36 abs fault code 113 ?
Posted: Sun Apr 29, 2012 6:23 pm
by monkey
i had a quick look at mates e36 abs fault today , i used carsoft and the fault i got out of it was 113 abs/asc feedback pump . i am guessing that's the valve block / pump assembly or a connection to it ? am i on the right track or does anyone have better idea ? thanks
Re: e36 abs fault code 113 ?
Posted: Sun Apr 29, 2012 8:34 pm
by monkey
just had a look on google and found that 113 could be something to do with n/s/f sensor / wiring too or from it . also seen about wiring faults inside the pump unit and soldering new wires . does this mean anything to anyone or should i not be using google for diagnostics
Posted: Sun Apr 29, 2012 8:37 pm
by bodger
is the car 4 cylinder?
Posted: Sun Apr 29, 2012 8:43 pm
by monkey
yes it's a 1998 318 touring
Posted: Sun Apr 29, 2012 10:43 pm
by bodger
Will be the abs pump ,apparently something to do with the battery being directly above the pump
Posted: Sun May 06, 2012 8:36 am
by monkey
i have found a replacement pump . the one fitted to the car is ATE 34511164896 and the one i have found is 34511164897 . anyone know if this will fit and work ok ? the pumps look the same and both are asc .
