Sill trim chromie
Posted: Wed Sep 04, 2024 4:54 pm
by Dlb26
As above, looking for a Passenger side lower sill trim for 1988 cab chromie as pictured.
Local dealer says zero stock in UK or Germany with no restock date. Mine is broken just where 2 of the clips fit meaning it needs to be attached with gobbo at those areas.
Part no. 51131932803
Re: Sill trim chromie
Posted: Fri Sep 06, 2024 11:45 am
by Speedtouch
Can you not patch, plastic weld or hot staple in more plastic/fibre glass to rebuild the areas? I often had to do this in a bodyshop to repair broken bits of trim, bumpers, etc.
Posted: Fri Sep 06, 2024 2:32 pm
by Dlb26
I'm thinking of something like this, it has a thin channel which should fit over the clips which would ordinarily be on the car first. I might attempt to attach the clips to the trim and then fit it as one item. Depends on how well I can attach the clips.
