325i cab exhaust downpipes
Posted: Thu Aug 24, 2023 1:34 pm
by guss300
Hi as per title need the exhaust downpipes for a 325i cab
Re: 325i cab exhaust downpipes
Posted: Fri Aug 25, 2023 7:55 am
by guss300
Anyone??
Posted: Fri Aug 25, 2023 7:11 pm
by BenHar
The "downpipes" on a cabriolet are no different from any other 325i.
The year of the car is what governs the spec for them.
Ben
Posted: Fri Aug 25, 2023 7:14 pm
by guss300
Many thanks for the info Ben. The car is a J reg. Has anyone got any??
Posted: Mon Aug 28, 2023 6:49 am
by guss300
Bump
Posted: Mon Aug 28, 2023 6:52 pm
by BenHar
If you use
https://www.realoem.com/bmw/select.do and put the vin number in you should be able to find the part number you need.
Ben
Posted: Mon Aug 28, 2023 7:00 pm
by guss300
OK thanks will look it up and put it on here
