So this is why I haven't been on here that much lately...
Posted: Thu Feb 20, 2014 10:30 pm
Been playing with this
Pics
Older snaps
On recovery duty at a Drift day
Info
'03 TD5 Land Rover defender 110 County Crew Cab
Exterior
Santorini Black
Clear front indicators and side repeaters
Black/silver Land rover bonnet and grille badges
Genuine Landrover D90 roof rack (for extra length and modified for crew-cab) with genuine land rover spots
Safari snorkel
Swing away spare-wheel carrier
Adjustable/removable towbar
+2inch wheel arches
side window wind Deflectors
tinted side windows
Tomb Raider side runners
Black chequer Plate sills, wing tops, rear corners and fuel filler
Black exmoor trim hood
Engine and drive-train
EGR delete
Performance panel air-filter
De-cat down-pipe
mid box replacement pipe
Performance Intercooler
VNT Turbo
Alisport Exhaust manifold
Silicon hoses
Boost limit box
ECU Re-map
Transmission
Discovery transfer box rebuilt with HD different cross-pins and cross-drilled input gear, high capacity sump
Rebuilt R380 gearbox with uprated lay-shaft and mainshaft bearings
Detroit Tru-trac front pegged differential
Detroit locking rear pegged differential
Suspension
Terrafirma Steering damper
2 inch lift kit
Full polybush kit
Castor correction and Cranked radius and trailing arms
Heavy duty solid steering arms
Heavy duty adjustable Pan-hard rod
Brakes
EBC Green-stuff pads
EBC drilled and grooved discs
Braided +2" brakelines
Off road protection/equipment
First Four tubular winch bumper and 10000lb winch with plasma rope
First Four front swivel recovery points
First Four front rock guard
Gwyen Lewis steering bar protector
Gwyen Lewis steering Guard
Gwyen Lewis front diff guard
Terrafirma rear diff guard
Terrafirma tank guard
Terrafirma transmission guard
Receiver hitch
Receiver hitch towing drop plate & recovery point
Bush wires
Jate rings
Military air intake
Twin jerry-can roof-rack holder
high lift jack and roof-rack holder
Wheels and Tyres
33x12.50x15 Hankook Dynapro MTs on Black 15x10 modulars
Interior
Factory electric front windows
Factory Alpine head unit
Land Rover carpet & rubber mats
Nardi Classic leather steering wheel
2+2 Recaro LS highback seats
Lockable custom center console
Bluetooth phone kit
Midland CB
Mud-stuff Tunnel Tray
Extra sound deadening
Tinted windows.
Future Plans
Re-trim the four Recaros to match
HD drive-shafts and drive-flanges (to put up with the diffs better)
Rear tub lockable compartment with tools
Rear work lights
Galvanised doors
Improved sound system (speakers, amp etc)
gauge pod
Madman Automotive EMSII
Squeeze in a TDV8 in if the TD5 jokes do become a reality :p
Eventually a galvanised chassis if it rots to bits
Pics
Older snaps
Info
Exterior
Santorini Black
Safari snorkel
+2inch wheel arches
tinted side windows
EGR delete
De-cat down-pipe
VNT Turbo
Silicon hoses
Boost limit box
ECU Re-map
Transmission
Suspension
2 inch lift kit
Full polybush kit
Brakes
Receiver hitch
Bush wires
Jate rings
Military air intake
Wheels and Tyres
Interior
Bluetooth phone kit
Midland CB
Tinted windows.
Future Plans
Rear work lights
Galvanised doors
gauge pod
