Changing Coras water pump
Posted: Mon Feb 25, 2013 5:21 pm
by kam-325i
51 Plate 1.2 Easytronic Corsa........z12xe engine i think....
Whats involved in changing the water pump, 'er indoor's mentioned that her car is making a "Funny Noise"....Lifted the bonnet, and found water being spun around the engine bay, the bearings have gone.
Re: Changing Coras water pump
Posted: Mon Feb 25, 2013 5:47 pm
by TheHeap
I think it's just engine mount, auxillary belt then pump.
I'm sure it's that's easy. Haven't done one for months but I don't remember it being a pain.
Posted: Mon Feb 25, 2013 5:58 pm
by kam-325i
i was hoping the engine mount could stay on !!!
Posted: Mon Feb 25, 2013 6:50 pm
by capnmchl
I think these are the chain drive engines, so it's like TheHeap says, jack the engine up, take the engine mount off and it's right infront of you.
Posted: Tue Feb 26, 2013 10:08 am
by kam-325i
Yep, chain driven cam engine.
Is it easier to take the pump pully off while its still connected to the engine ?
Posted: Tue Feb 26, 2013 4:20 pm
by capnmchl
Try and do it with the belt attached. If it starts slipping, find a way to put more tension on the belt and get it off. They're only some male torx bits if IIRC?
Posted: Tue Feb 26, 2013 4:26 pm
by kam-325i
Engine mount and pulley fixings are male Torx...gotta go buy a socket set for them.
