Parts clearout - M40b16, Auto box, Power steering kit
JackCornick
Thu Jan 03, 2019 7:58 pm
Hi all
Im having a bit of a clear out after converting my e30 to M50 power. All of the e30 parts have come from my 1990 316i automatic, which was in daily use until I began the conversion back in April. The car and parts have covered 69,991 miles and was working perfectly and reliably before I took it all apart. The Matte Black 'turd' in my signature is not the car that I'm talking about, lol. I'll get started:
M40b16 Engine - 69k - Working well and reliably when removed, last serviced 12 months and 6,000 miles prior to being removed. The head is clean and didn't tap or knock like some are prone to. I will break it for parts so just message me with requests. I can place the bulk of it on a pallett for collection if needed, same goes for the gearbox - Now being broken:
- Rocker Cover - SOLD
- Individual rocker cover bolts are free on request, if you buy something else lol
- Good working Head, no tapping! - £80
- Sump, oil pick up and dipstick - SOLD
- Coil pack, HT leads (12 months old), Distributor cap - SOLD
- Inlet Manifold - £15
- Throttle Body - £15
- Alternator - £40
-M40 Starter Motor - SOLD
-M50 Starter Motor - £25
- Wiring Loom - Missing the C101 plug as it was used for my conversion - £15
- Idle Control Valve - SOLD
- Metal water pump 12 months old- £10
- Any of the various sensors from the engine - £5
- Crank, Pistons, anything else you can think of pulling off an engine!
ZF 4hp22 Automatic Gearbox - Working well, shifted nicely, comes complete with oil cooling lines and dipstick - £100
Torque Converter - £50
4 cylinder exhaust back box back, front section now sold - Replica part bought from online parts website, its around 18 months old and I did about 6,000 miles with it. Single pipe exit which I painted black - Good usable condition - £40
Power Steering components
-Steering rack - SOLD
-PAS pump, drive belt and pulley - £35
-PAS pipes £25 (I stupidly cut one about 2” from the reservoir, I can send pics if you need a pipe)
E30 4cyl OEM springs - Probably original so 69k miles - £10
M50 Dual Mass Flywheel, Clutch and Pressure Plate - Came with my M50, looks a bit rusty, clutch plate has a decent amount of meat on it - £30
M50 Starter Motor - Came with engine, never used. Dropped in favour of M20 - £25
E30 Automatic Driveshaft - Good condition from my car - £40
OEM BBS Centre caps x3 - for 14" wheels - SOLD
Throttle Position sensor - £10
Fuel Pressure Regulator - £10
M40 Coolant Hoses - SOLD
M40 ECU -Yellow label 174 - £30
M40 Radiator - Comes with oil cooler connections for auto gearbox - SOLD
M40 Radiator shroud - SOLD
M40 throttle cable - £5
M40 Fuel hoses - from engine bay - £5
M40 Intake hose - SOLD
M40 airbox (not including MAF) - Includes a lovely browned air filter - £10
M40 MAF sensor - £50
M52 02 Sensor - SOLD
Pics!
Parts are all located in Burbage, Leicestershire. I can post most things of a reasonable size and weight for £10. Smaller things I will use MyHermes to post which will be up to £5. As I say I can place the engine on to a pallet for courier collection.
I can be contacted on 07747 441179. Text would be appreciated as I work shifts. I can send further pictures via whataspp upon request
Jack
You can't polish a turd, but you can paint it matte black
Fri Jan 04, 2019 12:39 pm
Great advert Jack good luck mate. :bmw:
By the way , would the auto box fit an M10 engine ?
E30 316 coupe 1986 (rip)
E30 316 Baur 1987 (Feeling sorry in the drive but alive !!)
E36 318ti Sport (rip)
E46 330 Ci SE (rip)
E46 330 Ci Sport
JackCornick
Fri Jan 04, 2019 1:44 pm
Hi Mart.
Looking at the drivetrain section on the E30 wiki page it looks like the M10 engine has a different bolt pattern to the M40, so looks like it won’t fit bud.
Fri Jan 04, 2019 2:21 pm
I dont need one mate, (hope not ) but for the record does the bell housing remove and then be usable ?
Mart. :cool:
E46 330 Ci SE (rip)
E46 330 Ci Sport
JackCornick
Fri Jan 04, 2019 4:00 pm
I wasn’t paying particular attention, but it seemed to be all one piece
Fri Jan 04, 2019 5:01 pm
Have a good look just for the hell of it please
mart.
E46 330 Ci SE (rip)
E46 330 Ci Sport
JackCornick
Fri Jan 11, 2019 10:13 am
Iv had a look, the bell housing is separate. It bolts up to the middle part of the box from the inside.
Porthos
Thu Feb 07, 2019 2:12 am
How much for the power steering rack? Shipped to the US?
JackCornick
Fri Feb 08, 2019 8:48 pm
Sorry steering rack is now sold, only have the pump and pipes left
JackCornick
Sun Feb 24, 2019 2:00 pm
Parts are selling, most of the ancillaries are now removed from the engine. Message me if you want anything. Thanks
rough_rag
Mon Feb 25, 2019 10:10 pm
pm sent
