M62 E30 alternator wiring/ build pictures
Posted: Sat Mar 08, 2014 6:26 pm
by andy179
Hi I wonder if anyone can help me with this, have put a 1997, m62b35 from an e39 into a facelift e30, have wired it up as per www.e30.de, everything works fine apart from my alternator warning light won't go out. the alternator is charging fine showing 14.4v at the battery when running just the warning light remains on , the alternator is the air cooled type with a B+ post and a 3 pin plug, only two of the pins are used middle being blue which I thought would be D+, the other pin is a green wire going somewhere into the engine loom. I have replaced the regulator today and still the same thing, am I missing something else? any help most appreciated thanks Andy
m62 wiring
Posted: Thu Mar 13, 2014 7:32 am
by andy179
Just a quick update got the alternator to work properly, looks like the wiring guide I followed http://wp1016621.server-he.de/fotost/f01934/f01934.htm leaves pin 6 of the x20 (greeen white) disconected. This connects to the other pin on my alternator (the green wire), looks like this needs a fused power supply, so hooked it up and all is well, the only other thing I added to this wiring information was the EWS 11 which fitted quite neatly into the E30, just looking for a better key blank to incorporate the transponder chip!
Re: m62 wiring
Posted: Sun Apr 27, 2014 5:33 pm
by Driftben
well done on sorting this andy, i would use any wiring codes found on the net as guidelines only because believe it or not some of the M60/M62 use different wiring setups.
so is she on the road now then?
Re: m62 wiring
Posted: Sun May 04, 2014 11:00 am
by andy179
Hi Ben yes finally mot'd and on the road really happy with it, just a bit of a firm ride for me, think it's the 17' wheel fitted, now looking for a suitable strut brace
Re: m62 wiring
Posted: Sun May 04, 2014 11:34 am
by andy179
Re: m62 wiring
Posted: Sun May 04, 2014 7:37 pm
by Gok
Looks sweet! Congrats buddy !
Re: m62 wiring
Posted: Sun May 04, 2014 8:12 pm
by andy179
Thanks, took me long enough, 18 months in all, new rear inner archers and holes in all the usual places! sorting the shell out took most of the time, I like many others followed dave's servo behind the glovebox approach which works well. will try and upload some more photos next week!
Re: m62 wiring
Posted: Sun May 04, 2014 8:35 pm
by andy179
PS for anyone interested an m60 water pump will fit the m62 with a bit of modification to one of the aluminium tubes running down the v. I moved the header tank hose to one of the rear sender ports (other port used for e30 water temp sender). the reason for using an m60 pump allows the use of a standard whaler thermostat, instead of the electronic one to keep things nearer 80degrees. there are conversion kits available instead of doing it this way, but I prefer my approach (and it worked out cheaper!)
Re: m62 wiring
Posted: Thu May 08, 2014 12:08 pm
by andy179
More pics added if anyone is interested
http://s1292.photobucket.com/user/andy791/library/
Re: m62 wiring
Posted: Fri May 09, 2014 5:51 pm
by Gok
Awesome :cool: liking the cheeky 320i badge ;) haha
Hopefully I'll progress more with mine.
Re: m62 wiring
Posted: Fri May 09, 2014 6:11 pm
by jimbom30cab
that's a great build there mate, you should be really proud of that. I've love to do that one day.
Bet it drives well, be epic to see some driving vids
Re: m62 wiring
Posted: Mon May 12, 2014 10:20 am
by Phill172
Car looks great, nice build.
Out of interest do you have issue with hot starting? I know 3 V8 cars including mine that wont even turn over when hot, wondering if its a wiring issue to the starter motor, and as you have been working out the alternator wiring maybe worth askign!
Re: m62 wiring
Posted: Mon May 12, 2014 12:36 pm
by andy179
Hi Phill, I have noticed once or twice a rumbling straight after start up from hot, I think this is caused by the exhaust manifolds being so close to the starter, there is no room to fit the heat shield, I've even bought another starter just in case. It does start just think the heat will cause the starter to fail at some point. I did run 70mm wire from the battery to the starter and used two 50mm earth straps to make sure there was no voltage drop, these engines do require quite a few amps as I found out when trying to use jump leads, maybe this could be your issue?
Re: m62 wiring
Posted: Tue May 13, 2014 1:46 pm
by Phill172
Thanks for that andy, i wrapped the exhausts but dont have the shield, maybe worth finding one then!
thanks for that!
