would e36 328 gearbox be fitted in v8 m62b35
Posted: Mon Nov 25, 2013 6:50 pm
by bmw_entusiastat
hi fellas i heard that gearbox S5D 320Z - HMU from 328i e36 could fit v8 m62b35 is it true ? because i am thinking of changing my 2,8 with m62... thanks in advance guys
Re: would e36 328 gearbox be fitted in v8 m62b35
Posted: Mon Nov 25, 2013 6:56 pm
by jmc330i
If it did, there would be a lot of V8 powered E30s popping up around here! I believe its only the V8 manual gearbox that will fit.
Maybe the 328i/M3 box could be used with an adaptor of some kind, but it wouldn't be a straight fit.
Posted: Thu Dec 05, 2013 10:20 am
by Phill172
There was a place selling a adapter to use a M5* gearbox a while ago, however they never put up infomation on it, no additional photos, no one that could actually show it worked and the starter motor was on the wrong side for RHD cars.
Also there was no infomation on what clutch/flywheel was to be used, i imagine the gearbox with the adapter would bolt together but not work...
In short, no you have to use a M6* box for a direct bolt on with stock parts
http://www.driftworks.com/forum/wanted/ ... plate.html
Posted: Sun Jan 26, 2014 5:56 am
by Dirty6
Thread dig! The ZF S5D 320Z was used behind the V8s. The E34 3ltrs I believe it was. It uses a different front half case. The part numbers on Realoem.
Posted: Mon Jan 27, 2014 8:53 am
by Phill172
But a ZF S5D from a E36 328 wont fit as it has the wrong bell housing - if you find a pile of those hanging around......
Posted: Mon Jan 27, 2014 9:32 pm
by Dirty6
It doesn't have a separate bell housing, but there are two different front halves available. A V8 pattern and a 6 pattern.
Posted: Mon Jan 27, 2014 10:38 pm
by jmc330i
So in theory, you could buy a new 3.0 V8 bellhousing from BMW and swap it on to a 328i rear casing.... certainly a nice idea, but looking at the price of a bellhousing on BMWfans, who is going to chance it??
Posted: Tue Jan 28, 2014 12:08 am
by Dirty6
Yes.
The price is the issue. Might make it impractical for yous fullas, where there are v8 boxs available, but for the likes of Willnz and myself it gives us a chance.
Posted: Tue Jan 28, 2014 11:44 am
by Phill172
Can you not get a v8 box shipped out?
Posted: Tue Jan 28, 2014 2:22 pm
by jmc330i
The cost of a V8 box plus shipping would be stupidly high, the cost of the box is bad enough!
If it works, get on. It would make it cheaper for us over here too :D
