correct reading tacho
Posted: Wed Aug 29, 2012 10:34 am
by Driftben
what have people gone for to achieve the correct tacho reading for a 6cylinder tacho?
i know that you will need to up the signal to accommodate the 8 cylinder signal coming from the ECU but what has everyone used to get this?
Re: correct reading tacho
Posted: Wed Aug 29, 2012 1:42 pm
by Jonsku
4-cyl code plug to instrument cluster + "signal halfer" between ECU and tacho (which takes every other pulse from rpm-signal away).
Simple and works well :)
Posted: Wed Aug 29, 2012 2:53 pm
by Driftben
I see, I remember you saying something like that before matey. Any idea how much a signal halfer is and where I can
Pick myself up one :)
Posted: Wed Aug 29, 2012 4:17 pm
by Jonsku
e30.de / stifter, should be around 40...50€.
Those can be bought on many "racer shops" as well, at least in USA there seemed to be many manufacturers. Should be easy to find with google :)
Posted: Wed Aug 29, 2012 8:32 pm
by Driftben
Hmmm very interesting will, what's the owners handbook part?
Does the e30 rear plugs fit the e34 cluster?
Posted: Thu Aug 30, 2012 8:40 am
by Driftben
Ahh i see, sounds interesting but the biggest problem for me is I scrapped the bloody e34 :(
I wonder if you could take the e30 cluster apart and butcher I mean replace the e30 tachometer with the e34 tachometer? Reason is I basically have none of them sensors that the e34 cluster would want to see so it would complain more than my mom all the time.
Posted: Sun Sep 02, 2012 9:04 am
by Driftben
ohh really? well would the coding plug be able to be adapted to fit the E30 cluster by any chance?
