This one has the supercharger and it made 362hp and 350lbs torque with the belt slipping only giving 0.2bar boost at the top end but 0.35bar at peak torque. After they sort the belt out it´ll be in the 420hp range with steady 365-370lbs at 5000rpm+
Quite good results of 356hp and 386lbs torque for a NA 4.4 engine.
Both running VEMS of course.
Re: Two on the dyno , M60B44 supercharged and M62B44
Posted: Sun Apr 15, 2012 2:30 pm
by e21Jason
Sweet, can you do a PnP Vems for the m62
Jason
Posted: Sun Apr 15, 2012 2:47 pm
by Gunni
I cannot at this time, but I can have a loom altered to suit the vems ecu.
Posted: Sun Apr 15, 2012 10:05 pm
by Driftben
thats a good gain from minimal mods really on the N/A M62.
could you pm a price for a Vems ecu and to map please gunni for a M60b40
Posted: Mon Apr 16, 2012 10:23 pm
by Gunni
There are no mods, it´s stock apart from the custom exhaust.
Posted: Fri Apr 20, 2012 4:51 am
by Jonsku
Did you by any chance happen to dyno the same engines with original ECU.
I don't see how a STOCK M62B44 would make 360hp / 520Nm. That's 70hp / 80Nm more than specced... all that just with a "new" ECU? No way
Posted: Fri Apr 20, 2012 8:21 am
by yamoda
Can the vems control the Vanos on a M62B46?
Posted: Fri Apr 20, 2012 11:13 pm
by phi1
would also be interested in the b40 mod map
Posted: Fri Apr 20, 2012 11:23 pm
by Gunni
Jonsku wrote:Did you by any chance happen to dyno the same engines with original ECU.
No dynoing with stock ecu.
I know the results are high, but this is what the dyno reported and it´s been a fair dyno in the past. Even though it was 10% lower it would still be very good for a B44
There is another B44 going on the dyno in a few weeks. it´ll settle what these engines are really doing I think.
Posted: Fri Apr 20, 2012 11:24 pm
by Gunni
phi1 wrote:would also be interested in the b40 mod map
I don´t know what you mean
yamoda wrote:Can the vems control the Vanos on a M62B46?
It can not in the appropriate way, it only has the ability to do 2 camshafts. It could in a way run two exhaust cams on the position of one of them but thats not what I call correct so my answer is NO.
Posted: Sat Apr 21, 2012 8:30 am
by yamoda
Gunni wrote:It can not in the appropriate way, it only has the ability to do 2 camshafts. It could in a way run two exhaust cams on the position of one of them but thats not what I call correct so my answer is NO.
There is no Vanos on the exhaust cams, just the 2 inlet cams, like the M62TUB44. So can I assume it would be OK?
Posted: Sat Apr 21, 2012 10:31 pm
by Gunni
In that case it could actually do it.
One of the intake cams would be called "exhaust cam" but thats it.
Posted: Sun Apr 22, 2012 12:31 am
by phi1
How much for a Vems ecu and map for a m60b40?
Posted: Sun Apr 22, 2012 7:34 am
by yamoda
Gunni wrote:In that case it could actually do it.
Thanks Gunni,
I'll be in touch once the engine is in the chassis.
Posted: Tue Apr 24, 2012 8:41 am
by Phill172
As ph1 said, how much for a plug and play vems set up for a M60B40, could the same ecu (loom modified) be used later on in a M62B44 or maybe a S62?
Posted: Wed Apr 25, 2012 10:14 pm
by Gunni
The wiring between the M60´s, M62´s and S62´s are so different it wont work together.
PM for details.
Posted: Sun May 06, 2012 12:29 am
by bmwrobbie
we sorted the belt slip on mattys car and it pulls like a train we aint had it for a power run yet big thanks to gunni massivly recomended
Posted: Thu May 10, 2012 11:58 pm
by sparkyE30
saw the car at teesside on sunday and monday.it is a machine and the noise from it is unreal
Posted: Fri May 18, 2012 12:19 am
by Gabor325ix
Hi Jonsku!
I'm Gabor from Hungary. I'd like to show you another V8. It's a stock M60B40, with home made exhaust, DTA S60 pro ecu, light flywheel and some kind of spec. clutch.
By the way, those exhaust manifolds are looks awesome.
In the middle of the page, you can find a Dyno sheet.
It also produces around 360hp. The torque is a little bit less, somewhere around 480Nm, but its "only" a B40.
Perhaps ignoring the environmental standards gains this much.
Greetings from Hungary!
Posted: Tue May 22, 2012 12:04 pm
by Jonsku
Hello Gabor,
sorry but in my opinion those figures are way over what is achievable in real life, and as such I highly doubt the accuracy of you dynos..
I base these arguments on three M60B40 that have been dynoed on different places that have been proved to be very accurate. All of them were dynoed before and after the changes were made.
Stock the engines made 280...290hp. With reprogramming the other one "live on dyno", it made slightly over 300hp and couple of Nm under 400Nm. One with "ebay chip" made 310hp / 420Nm (though that one had highest dyno figure in the first place). So realistically these two made same hp after chipping, though the "ebay chip" never got as good behaviour to the engine as the "live-mapped" one.. And both had "reworked exhaust", otherwise realistically stock engines.
The third one, also with "reworked exhaust" made roughly 350hp / 430Nm with heavily reworked heads and grinded cams etc..
Thus, I'd say roughly 300hp / 400Nm is limit with pump-fuel for stock M60B40. B44 might be able to give 10% more but that's about it, unless you start playing around with heads..
M60B44 with worked heads / cams and proper exhaust might, on the other hand, get you quite near 375hp / 475Nm figures on a streetable car.
Posted: Tue May 22, 2012 1:14 pm
by Driftben
What are these 'eBay chips' you speak of jonsku? Are they any good and worthy of a buy?
Posted: Tue May 22, 2012 4:01 pm
by Jonsku
Driftben wrote:What are these 'eBay chips' you speak of jonsku? Are they any good and worthy of a buy?
I wouldn't recommend those, yes they will give you more power but on mid-range the engine behaviour is not as good as it used to be etc.. just better to get the engine mapped on a proper dyno / road.
My point is not to argue if some dyno is accurate or not, or if some chip gives 15 or 25 hp. Just to point out, that there are "impossible" claims that should be proven before people start believing in such numbers...
The bottom line is, that whatever the "dyno figure" is, most important thing is that the engine works as it should (or even better), and that the owner is happy with the performance.
Posted: Tue May 22, 2012 7:27 pm
by SuperchargedV8Touring
This is exactly what I'm looking for in the end - a driveable engine. I'm not saying I haven't got a figure in mind that I'd like to see come up on the dyno, but I'd be much happier with a decent graph line for hp and torque.
I've had a modded car in the past which I didn't get mapped etc and it wasn't that satisfying to drive unless you were giving it the beans everwhere......
Posted: Wed May 23, 2012 6:58 am
by e21Jason
I had a dastek ecu on my 540 mapped by shepsevo on here and it made about 320bhp on a stock engine
Posted: Wed May 23, 2012 8:57 am
by Driftben
So is it dastek ecu or uni chip that you guys have got fitted?
Posted: Wed May 23, 2012 2:27 pm
Mine will be running on Emerald K6.
Posted: Wed May 23, 2012 8:28 pm
by Driftben
What made you go for that one Michael
Posted: Wed May 23, 2012 9:59 pm
Hi Ben, There's a fair amount of choice out there and I didn't do a ton of research TBH, but it will do a decent job of running my supercharged M62B44.
The Emerald seems pretty good value for money to me and can be upgraded as they develop new models. I also like the 3 position dash switch which allows complete map changes on the fly.
I went for a standalone ecu because the M62B44 is a little trickier to wire into an E30 than the M60B40 (so I was told) and also because I wanted to get the most out of my set-up and the standard ecu is restrictive (as they all are!).
Posted: Wed May 23, 2012 10:58 pm
by Gunni
I had another M62B44 on the dyno it showed 308hp which is alot more plausible .Same ignition advance same amount of fuel.
Posted: Thu May 24, 2012 7:13 am
Hi Gunni, with your experiences of M62B44s on your dyno, what would you estimate my set-up to show?
It's a std M62B44 with full custom manifolds and system, water methanol, Emerald K6 and an ESS VT1 7psi s/c.
Cheers!
Posted: Thu May 24, 2012 9:50 pm
by Darrenr
Gunni can i ask why did lewis's make 340 ish and petes only make 308? What where the differences?
Ive got custom manifolds on mine do you think that would make a difference?
Posted: Fri May 25, 2012 12:48 am
by Gunni
I don´t know why there was a difference.
Posted: Sun Oct 21, 2012 1:38 pm
by oze30
My 340 made 286BHP and that was a standard M60B40.
