What throttle cable is required?
Posted: Tue Mar 06, 2012 8:19 pm
by phi1
Hi there, what throttle cable do people use? also on the m60 how does it work because it has 2 throttle bodies like one and then the main one how does that work?
Cheers Phil
Re: What throttle cable is required?
Posted: Wed Mar 07, 2012 8:12 am
by Jonsku
E30 throttle cable is too short, you need to have M60 throttle cable.
The second throttle body is for ASC, which you should get rid of. You can either buy the longer rubber-boot ( http://bmwfans.info/parts/catalog/E34/S ... ow_sensor/ ) or or remove the flap and block the holes.
I've always done the second option as it makes using silicone hoses much easier (you need to shorten the rubber boot a bit in order to make it fit nicely).
Here's a picture; http://www.m5time.com/albums/Cars2/E30_ ... M5TIME.jpg
