M60s rear LSD
Posted: Mon Aug 01, 2011 10:54 pm
by Driftben
iv just realised that the 5 has a LSD in the bad boy, if i change the rear diff cover would it fit on the E30s sub frame mounts?
also i think it may need abit of love given to it.... is there anyone on here that rebuilds them?
thanks
ben
Re: M60s rear LSD
Posted: Wed Aug 03, 2011 9:02 am
by BaldBimmer
The 5 has a large case diff and the E30 can only take small or medium case diffs. Internal pars cannot be swapped between medium and large case diffs so if you want to use the 5 series LSD then you'll need to put the whole rear subframe in which is quite a job but possible. I've used a 525d medium case 2.64 LSD which bolts straight in after changing the rear cover to an E30 one.
Re: M60s rear LSD
Posted: Wed Aug 03, 2011 10:13 am
by Driftben
do all 525d have lsds then or is it a option?
what a complete arse that would be changing the rear subframe just for a rear diff to fit? fell quite gutted that i now have to find another one :cry:
Re: M60s rear LSD
Posted: Wed Aug 03, 2011 4:18 pm
by e21Jason
E28 large case diff bolts into a e30 subframe, and the e28 hubs can me modified to fit the trailing arms. need a new diff mounts to the chassis and drive shafts for the larger hubs.
This is how prodrive built the rally cars and hass been copied by rally m3's since.
Not sure if the e34 diff works
Jason
Re: M60s rear LSD
Posted: Wed Aug 03, 2011 10:32 pm
by Driftben
well today i was half way struggling getting the rear diff off when i realised that it wasnt a LSD :cry: so im now on the hunt again for a booming LSD. more money :roll:
interesting about the E28 way of things jason. how hard are the E28 LSD to come by?
thanks
ben
