M60 ECU's
Posted: Sat Jul 23, 2011 10:52 pm
by chips
Is the same ECU used for manual and automatic M60B40's?
I have an engine and ECU from an auto car and a gearbox and loom from a manual car. Can I use the ECU from the auto car?
Re: M60 ECU's
Posted: Wed Jul 27, 2011 10:37 pm
by e30mtech
did you find an answer mate mind i still got the ecu here as well if you do need it.
adam
Re: M60 ECU's
Posted: Wed Jul 27, 2011 11:32 pm
by chips
Cheers Adam. I haven't found out yet. Although I'm pretty sure it's just a case of jumping the pins for the connection to the autobox that tell the ECU not to start the car if the auto box is not in neutral. Also there must be differences between the 3.0 and 4.0 ECU's.
Re: M60 ECU's
Posted: Tue Aug 16, 2011 12:06 pm
by chips
Can anyone confirm this?
Re: M60 ECU's
Posted: Fri Aug 19, 2011 6:29 am
by Jonsku
Yea the ECU's are the same, also in B30's. The chips are a bit different, though I'm not sure if that really matters as the pin-outs are exactly the same in all of them.
Maybe someone has researched this further?
