would e36 328 gearbox be fitted in v8 m62b35
- bmw_entusiastat
hi fellas i heard that gearbox S5D 320Z - HMU from 328i e36 could fit v8 m62b35 is it true ? because i am thinking of changing my 2,8 with m62... thanks in advance guys
If it did, there would be a lot of V8 powered E30s popping up around here! I believe its only the V8 manual gearbox that will fit.
Maybe the 328i/M3 box could be used with an adaptor of some kind, but it wouldn't be a straight fit.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
There was a place selling a adapter to use a M5* gearbox a while ago, however they never put up infomation on it, no additional photos, no one that could actually show it worked and the starter motor was on the wrong side for RHD cars.
Also there was no infomation on what clutch/flywheel was to be used, i imagine the gearbox with the adapter would bolt together but not work...
In short, no you have to use a M6* box for a direct bolt on with stock parts
http://www.driftworks.com/forum/wanted/ ... plate.html
So in theory, you could buy a new 3.0 V8 bellhousing from BMW and swap it on to a 328i rear casing.... certainly a nice idea, but looking at the price of a bellhousing on BMWfans, who is going to chance it??
James
'91 325i Sport
'91 325i Sport
The cost of a V8 box plus shipping would be stupidly high, the cost of the box is bad enough!
If it works, get on. It would make it cheaper for us over here too
James
'91 325i Sport
'91 325i Sport
