M60 manual flywheel & clutch
Driftben
Sat May 21, 2011 10:06 am
im in despite need of a manual flywheel and clutch for my M60b44 6 speed conversion,
just wondering what everyone has used? need to get it ordered so i can get it for next weekend :D
thanks
ben
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Jonsku
Sun May 22, 2011 7:16 am
Ummm.. M60B40 or M62B44? :)
Anyway, if you're using 6-speed 'box you can use M60B40 clutch/flywheel or M62B44 clutch/flywheel. However, these two can't be mixed as they've different size clutch discs.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Driftben
Sun May 22, 2011 8:19 am
Ahhaa caught me out.... M60b40 is the one i have.
Im looking for a lightened flywheel and clutch setup but can't find one anywhere. It's like looking for prince Williams hair piece.
I'm also struggling getting the auto torque converter and flywheel of the m60 as well if you have info on that too îa–
Ben
6pot wilwoods front
4pot Porsche rear
yamoda
Sun May 22, 2011 11:11 am
Here you go
http://www.ttvracing.com/
Very reasonable prices as well.
Driftben
Sun May 22, 2011 3:42 pm
thanks for that mate, iv emailed them so awaiting on a price. have you ordered from them at all?
6pot wilwoods front
4pot Porsche rear
e21Jason
Sun May 22, 2011 4:14 pm
My mate got a ttv s62 flywheel the other week, very nice bit of kit and took a week to arrive
customer service is stereotypical British engineering company style
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
chips
Was Pzero
Was Pzero
Sun May 22, 2011 4:31 pm
To get the torque converter off you need to look under the engine, you will see a big rubber plug or a hole looking through to the flywheel if the plug is already missing. There are 4 bolts on the back of the flywheel that hold the torque converter to the flywheel. Rotating the torque converter will allow you to align the bolts with the hole so that you can undo them with a socket. Once you have all 4 off, the torque converter will almost fall off so be careful. That will give you access to the 9 bolts that hold the flywheel on.
I was told to do it while the gearbox was still attached, but only after I had already removed the gearbox.
Driftben
Sun May 22, 2011 5:24 pm
so they are helpful and enthusiastic aye jason haha
thats great advice thanks chris, it would of taken me hours if not days to find that out. ill let you know how that goes once the engine is out.
im still trying to order all the bits so everything will be on its way next week i hope ready for a long beer filled cut knuckled weekend.
6pot wilwoods front
4pot Porsche rear
