Cps
Posted: Tue Aug 24, 2021 6:30 pm
Not starting. Stopped while out driving but restarted and got home, no rough running or any other problems. 2 days later it won’t start. Turns over fine, good battery, fuel pump primes but no spark. Nor is there any movement on the rev counter when cranking. All points to cps but it checks out fine with 535 ohms. Done a continuity test of the 3 wires to ECU all good, What are the chances of the cps being faulty even though it checks out. Any suggestions appreciated. As this is one of those sensors that should be bought OEM and not cheap I’d like to eliminate all possibilities before raiding the piggy bank.
