clutch kit options
Posted: Mon Sep 09, 2013 2:20 pm
by moggie
so the winter is nearly here and i will be starting to get some bits ready for my s54 swap,i have all the info on the swap but im wanting to use the m20 flywheel lightened and balance to connect the s54 to the e36 5 speed box,my question is which would be a suitable clutch kit to use,i know it will need to be for the m20 flywheel and when people turbo the m20 they use sachs clutch kits, will this hold the power.thanks.craig.
Re: clutch kit options
Posted: Mon Sep 09, 2013 11:53 pm
by billgatese30
Thread moved from E30 Chat to S50 Engine Swaps. Your thread should receive the correct responses when posted in the correct forum area. Please try and think about the subject of your thread before you post and consider if you are posting in the correct section.
Regards,
E30Zone Team.
Posted: Tue Sep 10, 2013 12:32 am
by ajay
I would re think the m20 flywheel bit on an s50,s54 i have heard of someone trying it, but not for long. You would save yourself a lot of grief with a decent S50 lightweight flywheel (TTV) or something like that, more expensive but good quality and tried n tested by many. Cutting corners doing an s50 will cost you DEAR! GL
Re:
Posted: Tue Sep 10, 2013 7:16 am
by moggie
thanks ajay,i will look into an s50 lightweight option ,im planning on keeping it for a long time so i want it right.
Re:
Posted: Wed Sep 18, 2013 10:59 pm
by crossie
http://www.driftworks.com/driftworks-bm ... wheel.html
few guys I know run these
I have a ttv with a standard clutch kit(euro car parts) - no problems
s50 with 5 speed box
