anyone running a S50 with the evo sump?
Posted: Tue Jul 03, 2012 12:59 pm
by crossie
Saw this and it looks like the dip stick is in the correct place for an evo sump?
http://www.speedhunters.com/2011/07/car ... style_e30/ for the rest of the photos!
Re: anyone running a S50 with the evo sump?
Posted: Sun Jul 29, 2012 11:29 am
by PazzaAE86
Ive been told, by a person who actually had an S50 powered E30 and was driving it at an event that i was at, that on his car he used the E36 subframe complete. That would allow you to use the stock sump setup.
Other people on the internet have told me its not possible however... But that pic would lend to the argument...
Posted: Sun Jul 29, 2012 12:31 pm
by jmc330i
I've also heard of the possibility of using the E36 subframe, but its not straight forward from memory. I can't remember the problems.
It is certainly easier to use the M50 sump (and change the oil pump on the 3.2 lump).
Posted: Sun Jul 29, 2012 8:07 pm
by crossie
jmc330i wrote:I've also heard of the possibility of using the E36 subframe, but its not straight forward from memory. I can't remember the problems.
@JMC
can you have a think as I really interested in getting the evo sump fitted.
Really wish I had kept hold of the E36 subframe - a going to have to find a cheap one!
Posted: Sun Jul 29, 2012 8:21 pm
by jmc330i
I'll have a word with my mate who looked into when I see him next - not sure when that will be though.
I've something going round my head about the subframe bolting up, but the front suspension became an issue for alignment - really not sure though, there's lots of useless info filling my head up lol
How come you want to use the EVO sump? Not much of an advantage as far as I know
Posted: Sun Jul 29, 2012 8:25 pm
by crossie
Evo sump = twin pick up
plus sump is inline with the wheels and is not hanging low out the front.
York has loads of speed bumps
and also as the car is a track car am worried about using too much kerb.
Posted: Sun Jul 29, 2012 9:09 pm
by DanThe
The E36 crossmember does bolt up but the engine is so far back the bulkhead/trans tunnel needs major surgery
Posted: Mon Oct 01, 2012 6:43 am
by UweM3
DanThe wrote:The E36 crossmember does bolt up but the engine is so far back the bulkhead/trans tunnel needs major surgery
The E36 subframe has the engine mount tabs on the opposite site compared to an E30 subframe. Bolts up, but engine position is not suitable. As mentioned before, you need to cut a large hole in your fire wall to make room for th engine.
