ARB near exhaust manifold/wishbones
Posted: Thu Jun 07, 2012 4:30 pm
by crossie
does you Arb tap/hit your exhaust manifold?
or is it fine one the car is on the ground - only problem while on axle stands?
Re: ARB near exhaust manifold/wishbones
Posted: Thu Jun 07, 2012 5:55 pm
by E30BeemerLad
I only got this when he car was in the air when I had my S50 manifold on the M52 in the touring.
But I think the pipes had been modified from standard too and they still touched with the suspension free to hand down.
Posted: Thu Jun 07, 2012 6:19 pm
by backspring
mine touched whilst jacked up but when on the ground left me with a 1cm gap, didnt feel comfortable with it so i ended up using spacers on the arb mounts, now i have 3cm.
but some people dont have problems i did.
Posted: Thu Jun 07, 2012 6:29 pm
by jmc330i
What exhaust manifold are you using? Never had a problem on mine - in the air or on the ground.
Posted: Thu Jun 07, 2012 11:53 pm
by ajay
Mine looked like it would never clear the btb exhaust when it was up on a 4 arm ramp but cleared with no issues when on the ground!
Re:
Posted: Fri Jun 08, 2012 12:38 pm
by crossie
S50 standard manifold
do you have a photo of your spacers?
Re:
Posted: Fri Jun 08, 2012 1:36 pm
by jmc330i
crossie wrote:S50 standard manifold
Modified to fit the E30 I take it?
Mine was a btb one, which is basically a modified S50 manifold. Sounds like you might need to space the arb down a little to get the clearance if your manifolds weren't modified enough to clear them.
Re:
Posted: Fri Jun 08, 2012 9:54 pm
by DMS
Just make a new ARB
Re:
Posted: Sat Jun 09, 2012 8:20 am
by crossie
jmc330i wrote:crossie wrote:S50 standard manifold
LOL - E30 modified to take the S50 manifold!
Re:
Posted: Sat Jun 09, 2012 9:46 am
by jmc330i
crossie wrote:jmc330i wrote:crossie wrote:S50 standard manifold
Interesting.... get some pics up. That is a different approach to the conversion
It would also explain the manifold hitting the ARB I guess. You may struggle for advice as most conversions on here use modded manifolds, rather than completely standard ones with the car modded around them.
At a guess (without seeing pics), you'll probably have to space the ARB down.
Re:
Posted: Sat Jun 09, 2012 5:35 pm
by crossie
Sorry no photos yet just seen this.
My car is lhd so helps with getting the manifold to fit.
Will post photos tomorrow
Re:
Posted: Sat Jun 09, 2012 5:43 pm
by jmc330i
Ah, yup LHD definitely helps lol
Re:
Posted: Mon Jun 11, 2012 7:38 am
by DMS
jmc330i wrote:It would also explain the manifold hitting the ARB I guess. You may struggle for advice as most conversions on here use modded manifolds, rather than completely standard ones with the car modded around them.
That's exactly my approach:
-modify firewall
-modify subframe
-change ARB
-different lollypop
My car is also a LHD
Re:
Posted: Mon Jun 11, 2012 6:33 pm
by PazzaAE86
I spaced the ARB down, modified the firewall and ran treehouse racing lollypops to clear the manifold, but the manifold sits too low so the bottom flanges will need cutting off and welding higher up, unless your car is mega high.
Re:
Posted: Fri Jun 15, 2012 12:54 pm
by crossie
PazzaAE86
Which mounts are you using?
Re:
Posted: Sun Jul 29, 2012 11:33 am
by PazzaAE86
Sorry for the late reply, i used the traditional M5 mounts, modified to be stiffer.
Re:
Posted: Mon Aug 06, 2012 4:59 pm
by crossie
no worries mine is almost done and finished now
am sure it will be too low but at the minute stardard is all I can afford!
