S50B30 Wont Crank...
Posted: Tue Mar 20, 2012 7:44 pm
by PazzaAE86
Hi guys,
Tried firing up my S50 swap tonight, no joy, doesnt crank.
I know the starter is good as i've bridged out the Relay and i can get the engine to crank. Basically there is 12v to the feed of the Starter Relay when the key is turned (the thiner black and yellow wire) but nothing comes through the relay. As i say, i can bridge this out but it doesnt run, just cranks with no fuel or spark.
I have a large earth strap fitted in the stock E36 posistion, and have fitted the other earths that i can see (one off the Diag Port thing and one off the relay block).
Anything obvious/common? Dead ECU? Some S50B30's had EWS right? Is there a way i can tell?
Thanks!!!
Fuel pump is working.
Re: S50B30 Wont Crank...
Posted: Tue Mar 20, 2012 7:58 pm
by DanThe
Sounds like EWS is your problem here
Posted: Tue Mar 20, 2012 8:24 pm
by penton08
As above, A lot of s50b30's have EWS. Take the chassis number off the top of the ECU and ring BMW to confirm if it has EWS or not.
Posted: Tue Mar 20, 2012 8:38 pm
by DanThe
Silver label on the ECU will tell you this :wink:
Posted: Tue Mar 20, 2012 8:41 pm
by PazzaAE86
Red label on DME.....................
Posted: Tue Mar 20, 2012 11:10 pm
by PazzaAE86
Hmm the main white relay on the E36 loom wasnt clicking when i tested it the first time.. A few tests later, and a double check that my makeshift test wires were on again and it started clicking/has continuity... Lets hope that is the cause?
Posted: Wed Mar 21, 2012 6:54 pm
by PazzaAE86
It wasnt the cause. I stupidly had the power connector that lives by the three (five) main relays connected to the body as i thought it was earth.. I pulled the sheeth back to see a red wire :eek: Shit balls.
So anyway, it cranks now but wont start.
Im concerned that putting that power lead to earth, and then ferking about jumping the relay etc and giving both sides of the relay power has done some damage to the loom/sensors maybe?
That, or i got lucky and it just plain doesnt start for some other reason.
Posted: Wed Mar 21, 2012 9:52 pm
by PazzaAE86
Crank Shaft Sensor reads 550 Ohms or so..
Cam Shaft Sensor EXH Side reads 1220 Ohms or so..
Cam Shaft Sensor IN Side reads nothing, no Ohms.
Would point towards a dead Cam sensor, but dont know if this would stop the car from running..
Posted: Fri Mar 23, 2012 7:21 pm
by crossie
any luck ??
Posted: Fri Mar 23, 2012 8:31 pm
by PazzaAE86
Yep, runs now :) DME was dead, after loads of checking and arsing about looking elsewhere for faults.
Posted: Sat Mar 24, 2012 10:58 pm
by crossie
well done!
