Hesitiation on part throttle...
Posted: Fri Jun 03, 2011 10:17 am
by jonnie
Hey Guys,
Read a few people mentioning that they've had a hesitation on part throttle at low rpms on there S50's.
I seem to have this also...
Anyone find the solution?
Apart from that it flys
Re: Hesitiation on part throttle...
Posted: Sun Jun 05, 2011 8:18 pm
by jonnie
Anyone?
Posted: Sun Jun 05, 2011 9:31 pm
by fixedwheelnut
I'd start by getting the codes read to see if anything shows up, then check the valve clearances/ CO readings, [measured at each exhaust port] and the throttle switch often overlooked on older cars it is an Inspection two service item on S50 M3's
Posted: Mon Jun 06, 2011 9:32 am
by jonnie
The TPS is new, valve clearences just done, but I will put my diagnostic software on it and see what is comes up with.
I'm more interested that I've read a few people have had the same problem on here with their s50 converted cars and would like to know if they have solved it and what it was?
Posted: Tue Jun 07, 2011 11:59 am
by Larsen-Racing
Mine is hesitating at WOT, not part throttle. So we don't have the same problem.
Try to unplug you MAF while the engine is running, you shall hear a small change in the idle. If you don't the MAF is toasted.
Posted: Sun Jun 12, 2011 10:39 pm
by jonnie
All sorted!! Just had the lambdas the wrong way round! Doh!
