Manifold
Posted: Sun Dec 26, 2010 7:32 pm
by HenryM3
This is a pic of the S50B32 manifold after modding thats on my car, hope it helps someone.Image
Re: Manifold
Posted: Sun Dec 26, 2010 7:37 pm
by GeoffBob
Hmmmm, tastey. Nicely crafted :!:
Re: Manifold
Posted: Wed Dec 29, 2010 12:49 pm
by reggid
what are the primary and secondary ID?
Re: Manifold
Posted: Wed Dec 29, 2010 7:57 pm
by UweM3
GeoffBob wrote:Hmmmm, tastey. Nicely crafted :!:
most of that is S50 stock manifold. BMW didn't skimp for a change.
Re: Manifold
Posted: Wed Dec 29, 2010 8:44 pm
by HenryM3
All of it is, 4 & 5 have become 5 & 6 and as you can see 4 is made up from another 5 and bits of the old 6 the very slight reshaping of the collector was to clear the ARB.
Re: Manifold
Posted: Thu Dec 30, 2010 9:08 am
by UweM3
HenryM3 wrote:All of it is, 4 & 5 have become 5 & 6 and as you can see 4 is made up from another 5 and bits of the old 6 the very slight reshaping of the collector was to clear the ARB.
you haven't got some bit's left by any chance? I would like to "turn" my No6 round.
Have you done it yourself?
Re: Manifold
Posted: Thu Dec 30, 2010 5:39 pm
by HenryM3
As you can see No4 has a couple of sleeves, I got a bit of stainless tubing and cut those sleeves off it and made up the shape from bits I got of Ian, to get it right I had a piece of metal drilled to match the stud pattern on the head then I was able to bolt the manifold to it so that when I was pissing about with No4 everything else was solid. The collector box for 123 I cut and filed to get the shape I wanted and believe it or not I held them together with cable ties and took it along to the guy who welded it. If only I could weld like that. I have some bits in the shed, I'll look tomorrow but I don't think there's anywhere near enough to do another pipe. I'll let you know one way or the other.
Re: Manifold
Posted: Thu Dec 30, 2010 7:34 pm
by UweM3
HenryM3 wrote:As you can see No4 has a couple of sleeves, I got a bit of stainless tubing and cut those sleeves off it and made up the shape from bits I got of Ian, to get it right I had a piece of metal drilled to match the stud pattern on the head then I was able to bolt the manifold to it so that when I was pissing about with No4 everything else was solid. The collector box for 123 I cut and filed to get the shape I wanted and believe it or not I held them together with cable ties and took it along to the guy who welded it. If only I could weld like that. I have some bits in the shed, I'll look tomorrow but I don't think there's anywhere near enough to do another pipe. I'll let you know one way or the other.
cheers boss.
I only need one pipe with the flange. The rest will be doable more or less. Just want the No6 to point in the same direction as No5. And having LHD helps a lot. I don't need to make any changes to 1-2-3
Re: Manifold
Posted: Sat Jan 01, 2011 4:48 pm
by HenryM3
This is what I have been able to dig out, if any or all of it is of interest to you let me know and I'll get it off to you.
Re: Manifold
Posted: Sat Jan 01, 2011 5:42 pm
by UweM3
HenryM3 wrote:This is what I have been able to dig out, if any or all of it is of interest to you let me know and I'll get it off to you.
PERFECT! That will be a great help. Going to PM you
Re: Manifold
Posted: Wed Jan 05, 2011 9:21 pm
by HenryM3
sorry about the delay Uwe, by the time I had parceled it the Zone had gone down and I couldn't retrieve your address, it will be posted in the morning
Re: Manifold
Posted: Thu Jan 06, 2011 6:27 am
by UweM3
HenryM3 wrote:sorry about the delay Uwe, by the time I had parceled it the Zone had gone down and I couldn't retrieve your address, it will be posted in the morning
no rush, please take your time. I won't round working with the manifold soon anyway.
Engine mounts need to be done first.
