Page 1 of 2
What engine mounts should i use
Posted: Wed Nov 11, 2009 1:25 pm
by feens
As title ive read that the e28m5 engine mounts are a bit soft for the s50 conversion what other mounts should i use? Poly mounts were mentioned but ive no idea off what car ect
Thanks Brian
Re: What engine mounts should i use
Posted: Wed Nov 11, 2009 2:21 pm
by billgatese30
I have AKG mounts on mine and they work great, they are pricey though.
http://www.akgmotorsport.com/e30products.html
Second from the bottom of the page.
Posted: Fri Nov 13, 2009 1:58 pm
by feens
Cheers for that dude :cool:
Posted: Tue Feb 09, 2010 7:59 pm
by BMWLOVE100
get the same mounts you used to have
Posted: Tue Feb 16, 2010 12:44 pm
by jmc330i
feens wrote:As title ive read that the e28m5 engine mounts are a bit soft for the s50 conversion
Ive had no problems with mine.
Posted: Tue Feb 16, 2010 1:02 pm
by Jhonno
I did.. Fine with AKG's..
Posted: Tue Feb 16, 2010 1:44 pm
by DanThe
You will be fine until you start taking hard left handers, track day etc.
Posted: Tue Feb 16, 2010 3:02 pm
by Jhonno
Or hanging the arse out round left handers 8O
Posted: Tue Feb 16, 2010 11:22 pm
by jmc330i
Really? What happened?
Posted: Tue Feb 16, 2010 11:41 pm
by billgatese30
jmc330i wrote:
Jhonno wrote:
jmc330i wrote: Ive had no problems with mine.
Steering UJ interfere's with the exhaust manifold. This means that suddenly no more lock is available, and if timed wrongly can mean its difficult to wind the lock off as it can jam the UJ in place (happened to me on a hairpin with a pit wall on the inside as I exited and wanted to wind off the lock....not nice 8O )
AKG's sorted that out though :o
Posted: Wed Feb 17, 2010 12:04 am
by jmc330i
Hell 8O
How much room you got between the UJ and manifold? I wouldnt of said mine is overly close, but then I dont know how much the engine will move. Ive had no problems with mine, but Ive not tracked it yet.
Posted: Wed Feb 17, 2010 1:08 am
by billgatese30
I can't remember, it was starting to rain and I couldn't see much when I was changing them as my hands obscured the view. I don't think there's loads. start blipping the throttle with the bonnet open and see how much it moves, now add the cornering forces trying to move a 100+kg block of iron around and I'd imagine it moves even further. Its nice and firm on the AKG's though.
Posted: Wed Feb 17, 2010 8:53 pm
by Dezzy
I have just ordered a pair for the M50. Will be handy for the future. I am tight so am only using 1 though. Another E30 3.0lt 24v is using the other.
The way I see it 1 polly mount on the right and 1 635 mount on the left £9 from pelican parts and I should be golden. :D
Posted: Wed Feb 17, 2010 9:07 pm
by Jhonno
I fitted one.. My steering was constantly locked up as they are actually lower than the M5 ones.. 8O
Posted: Wed Feb 17, 2010 9:21 pm
by Dezzy
Jhonno wrote:I fitted one.. My steering was constantly locked up as they are actually lower than the M5 ones.. 8O
By how much mate? Can it be spaced? Enough threads?
Posted: Wed Feb 17, 2010 9:30 pm
by Jhonno
Erm, not sure, I should have measured, but I didn't have a lot of time so just pulled and swapped the other one!
There isn't a lot of spare thread..
Posted: Wed Feb 17, 2010 9:46 pm
by Dezzy
That might screw up plans. Rubbish!
Posted: Wed Feb 17, 2010 9:52 pm
by Jhonno
Don't be such a tight northerner.. :P
Posted: Wed Feb 17, 2010 10:06 pm
by Dezzy
Ha ha tight norther and brummie mate.
I have been thinking of ways to space it. Maybe make a nut for the thread like a M50/2 rockercover nut.
Drill the crossmember to suit. Big built in washer job job'd I reckon winkeye
Posted: Wed Feb 17, 2010 10:22 pm
by DanThe
Stop panicking you daft geordie, it will be fine :)
Posted: Wed Feb 17, 2010 10:24 pm
by Dezzy
DanThe wrote:Stop panicking you daft geordie, it will be fine :)
Ha ha thought you would like that matey. It's these M3 owners trying to sh1t up us tight daft northen monkeys. :eek:
Posted: Wed Nov 03, 2010 8:54 pm
by furbster
billgatese30 wrote:
jmc330i wrote:
Jhonno wrote: I did.. Fine with AKG's..
I had exactly that problem yesterday at Oulton Park (first trackday since the swap) Took me a while to work out what the problem was!!)
Am I correct in thinking the ones you are talking about in the link are part no #MM5030 ?
Posted: Wed Nov 03, 2010 9:26 pm
by DanThe
You must have been the white E30 I was struggling to keep up with :D
Posted: Wed Nov 03, 2010 9:27 pm
by billgatese30
Yep they look like the ones. $200 is what I paid back then too. :D
Posted: Wed Nov 03, 2010 9:33 pm
by furbster
billgatese30 wrote:Yep they look like the ones. $200 is what I paid back then too. :D
Brilliant! :D
And just changing the mounts totally cured the problem??
Posted: Wed Nov 03, 2010 10:12 pm
by billgatese30
Yep, 100% cured :D
Posted: Wed Nov 03, 2010 10:16 pm
by furbster
billgatese30 wrote:Yep, 100% cured :D
Thanks!!
I shall order a set up!! :D
Posted: Wed Nov 03, 2010 10:27 pm
by furbster
DanThe wrote:You must have been the white E30 I was struggling to keep up with :D
Hey Dan!
That would have been me!!
First time on track with that setup and what a differnt animal!.... Love IT!! :cool:
Sorry I didn't come say hello, I spent so much time driving or fiddling I didn't get to speak to any other zoners!! Which one were you driving?
Posted: Wed Nov 03, 2010 10:31 pm
by DanThe
Thats generally what happens, day goes so quick :)
I was in the lazer blue chariot, JEF plate, I was pretty much sailing past most standard looking E30's even though im still shite in some corners but remember one being particularly difficult! :D
Posted: Wed Nov 03, 2010 10:37 pm
by furbster
I did see you there, was behind you on the way home for a bit too when I was trying to avoid the traffic jam!!
I wish I'd made the time to come and find you now so that I could have taken a look under your bonnet!! See how the wiring loom really should look!
I'm back there on the 27th for a drift day with MSV. I don't suppose you're attending that one are you?
Posted: Wed Nov 03, 2010 10:44 pm
by DanThe
That traffic was a nightmare! My mate broke down half way through it, ended up taking us 3 hours to get to the motorway :cry:
We saw another 2 cars broken down and an accident involving 3 cars
All for the sake of a few cones and a set of traffic lights!
Wont be there for the diffin, will probably be next year before im out in it again
Posted: Wed Nov 03, 2010 10:54 pm
by furbster
I thought I saw you on the Motorway but I stopped for two hours in the pub to have something to eat and wait for traffic to die down!!!!
No doubt I shall be at many track and drift days next year so will probably bump into you at some point.
I best not keep spamming the thread!
I shall report back on this thread after fitting the mounts.
8) 8)
Posted: Wed Nov 03, 2010 11:12 pm
by DanThe
If you stopped for 2 hours then you probably did :)
Posted: Wed Nov 03, 2010 11:18 pm
by Jhonno
Brilliant! :D
Yes!!
Posted: Sun Nov 28, 2010 4:00 pm
by SCOTT325SE
is anyone running a manual rack with these engines/mounts?
