Servo / M Cylinder Problems and Answers
Posted: Sat Oct 31, 2009 10:36 pm
by e30mazm3
Just like to see what you s50 boys did to get round this problem in your own way. Pics would be awesome if poss.
Ive got a peugeot 307 servo and am planning to move it over and keep the stock master cylinder.....
Re: Servo / M Cylinder Problems and Answers
Posted: Sun Nov 01, 2009 10:17 am
by penton08
i used a polo g40 servo and a audi coupe quattro master cylinder. i did not need to move the servo over with this combo!
Posted: Sun Nov 01, 2009 10:29 am
by e30mazm3
Do you know the make and part no. of those?
Re:
Posted: Sun Nov 01, 2009 10:59 am
by penton08
servo is ate. i reckon a genuine audi master cylinder would also be ate, but i used a cheaper master cylinder form gsf. im sorry but i dont have the part numbers.
Re:
Posted: Fri Feb 26, 2010 6:14 pm
by Gunni
Coming back to this.
do you have a picture of said parts installed?
Re:
Posted: Fri Feb 26, 2010 7:08 pm
by Ant
mk2 clio servo and the OE m/cyl work for me, both in the OE location
E32 22mm M/cyl fits too, remote fluid res required though peeps.
Next one I think I'm going to loose the servo and put a proper bias pedal , twin m/cyl setup on instead.
^ should allow room to run a huuuuge carbon airbox with Alpha N algo
Re:
Posted: Fri Feb 26, 2010 7:35 pm
by Gunni
Haven´t you heard?
carbon airboxes and alpha-n is out,
Large turbo´s and mad accelaration is in
Thanks for that info, I think I´ll go for the clio servo on the setups I´m doing.
Re:
Posted: Fri Feb 26, 2010 10:49 pm
by billgatese30
I want to make my own pedal box so it uses standard cylinders (wilwood/tilton etc) and then supercharge the S50. (turbo's are for girls)
I might need your help with the second one Ant!
Re:
Posted: Fri Feb 26, 2010 11:15 pm
by Jhonno
Ant wrote:^ should allow room to run a huuuuge carbon airbox with Alpha N algo
Depends what you've done with the wiring.. The 4 pot wiring cover stops you being able to fit an e36 carbon airbox
