Does Anyone have an actual list?
- Brianmoooore
The only "definitely need" that I can think of for a M or S 5x conversion is a pair of E36 alloy engine mounting arms, and even these could be replicated in steel if the need arose. For everything else, there is at least one other option, and in most cases, many.
you will need,
e36 engine mount arms,
m535i engine mount rubbers,
e34 525 sump,dipstick.also oil pick up if 3.2 s50,
e30 brown temp sensor,
5 speed e36 m3 box,
e36 328 prop with e30 centre bearing,
e36 gearbox mount rubbers,
e30 gearbox mount,
e36 m3 radiator
5 speed e36 m3 box,
e30 gearbox mount,
e36 m3 radiator
- Rob_farmer
I have been also looking for such list, but nothing definitive found, therefore I have bookmarked following pages which do help a bit:
http://www.e30tech.com/forum/showthread.php?t=38010
http://www.e30dohc.com/wiki/index.php?t ... wap_Basics
http://www.e30tech.com/forum/showthread.php?t=115724
http://www.e30tech.com/forum/showthread.php?t=76315
http://forums.bimmerforums.com/forum/sh ... -I-learned
http://mye30.wordpress.com/
http://forums.bimmerforums.com/forum/sh ... 0-s50-cost
http://www.cartechbooks.com/techtips/bm ... gine-swaps
http://www.e30owners.com/forums/showthread.php?t=6808
I`m driving E30, 1989, 325i, 4 door. Restoring 1990, 4 door.
