M42 Gearbox ratios same as M40 gearbox ratios?
Posted: Tue Feb 05, 2013 10:43 am
by Ch4ni
Hi
Could someone please adivse if the M42 (Getag 240) gearbox is a close ratio (i.e. a sport gearbox) or does it have the same ratios as the standard M40 gearbox?
I am looking for a sport gearbox for an M40 engine does one exist?
Re: M42 Gearbox ratios same as M40 gearbox ratios?
Posted: Tue Feb 05, 2013 12:31 pm
by IlovM42
talking about E30 gearboxes they are all the same ratio for M40 and M42, but gearboxes from E36 are what you called "close ratio" as they have 5th gear with a 1:1 ratio (E30 ones have 1:1 ratio in 4th and 5th overdrive)
so an e36 gearbox on your M40 or M42 powerded E30 is a good improvement, I'm actually planning on fitting an E36 gearbox with a 3.45 diff, it will be more or less like having the stock gearbox with a 4,27 diff, but with longer 1st gear :wink:
Posted: Tue Feb 05, 2013 9:20 pm
by rix313
There is a slight difference but its very small IIRC.
Posted: Tue Feb 05, 2013 11:30 pm
by eko
I have an E36 M44 gearbox available for anyone looking :D
Posted: Tue Feb 05, 2013 11:52 pm
by senna
I replaced an E30 318is gearbox with an E36 box.
I found that the car was more refined on the motorway however overtaking (over 80MPH) required a change from 5th to 4th.
Around town there was not much difference.
Slight gains in economy.
Slight loss in in-gear flexibility.
It was running a 4.1 LSD
If anyone wants the old E30 M42 box (it jumps out of 4th occasionally when changing down from 5th at 80 mph)
£5 Collection Only SE24 London. (p.m please)
I have no use for it except for an autopsy
Posted: Wed Feb 06, 2013 7:57 am
by IlovM42
rix313 wrote:There is a slight difference but its very small IIRC.
slight difference? :eek: no so light
if you put an E36 gearbox keeping the same diff ratio it's like using only the 4 first speed of the E36 gearbox...
one of the best setup is M40/2/4 with E36 gearbox and 3,45 it's what i'm about to do on my 318is e30 and it's the setup on most 318is/TI E36 :twisted:
Posted: Wed Feb 06, 2013 8:42 am
by eko
I can also supply a 3.38 diff to go with the m44 box if needed :-)
