M40 and M42 Wiki pages
Posted: Sat Oct 08, 2011 9:33 am
by Grrrmachine
Morning all,
I'm cleaning up the Wiki, and the M40 and M42 pages are looking a little sparse:
http://www.e30zone.net/e30zonewiki/index.php/M40
http://www.e30zone.net/e30zonewiki/index.php/M42
If any one of you have some info that you think ought to be there, or can see errors (like hp figures, for example), then say it here and I'll make ammendments.
Pictures would also be a big help.
Re: M40 and M42 Wiki pages
Posted: Sun Sep 09, 2012 2:49 pm
by Grrrmachine
The M42 page has now been substantially revised, so if anyone wants to read it through and comment it would be appreciated.
Posted: Sun Sep 09, 2012 2:55 pm
by TPS
I can provide a picture of an M40 engine if you like.
Posted: Sun Sep 09, 2012 2:57 pm
by Grrrmachine
Sure, just post it in this thread. Saves me scouring the Photo forum
Posted: Sun Sep 09, 2012 2:59 pm
by TPS
I'll take some & put them up.
Posted: Sun Sep 09, 2012 11:26 pm
by TPS
Posted: Mon Sep 10, 2012 10:33 pm
by Grrrmachine
Lovely stuff, I'll get a pic uploaded asap.
M40 Wiki page is now done.
Posted: Fri Sep 14, 2012 1:58 pm
by chu346
Looking at the m40 page it shows the rod length as 135mm then below shows it as 140mm?
Posted: Fri Sep 14, 2012 2:45 pm
by rix313
Out of interest where did you get my guide for the COP conversion?
Posted: Fri Sep 14, 2012 2:46 pm
by Jos
M42 inlet manifold doesn't need swapped if you are using an e36 motor. The e30 is better but its not a requirement.
Posted: Tue Sep 18, 2012 9:34 pm
by Andyboy
A couple of pointers; the chain idler gear was replaced by a curved nylon guide rail in late 1993 at which point the old twin V belts were replaced by the serpentine belt. E36 engines have the same head but thinner valve stems and single valve springs. Excess crank endfloat is caused by the engine only having 180 degree thrust washers and not full 360 degree. Only later aircon cars have a dual mass flywheel.
Posted: Tue Sep 18, 2012 9:42 pm
by TPS
Will I notice better MPG replacing my M40 with a E30 M42 unit?
Posted: Thu Oct 04, 2012 7:55 am
by joeseth
Mine seems to do about the same mpg. That's with the 318i diff still, so if you put in the 318is diff will prob be better mpg.
Posted: Mon Oct 08, 2012 10:42 pm
by soul4t
Hi,
I have some close pics of my camshaft showing the oil spray bar...could be a help? Any car pix...got some of doing the timing belt too...are here:
http://s1211.photobucket.com/albums/cc4 ... ar%20bits/ You should be able to get direct links to the images.
There's nothing about the sensors or ignition...this write up is a good way to get people thinking properly about diagnosing their possibly sensor/ignition type faults I think? It's certainly a good read about how the DME for Motronic 1.1 and 1.3 works:
http://www.opel-scanner.com/files/DME_1.1_1.3.pdf
It might be good to have a link to the ECU section on the wiki!
Nice general page though, thanks for making/improving it!
