M42 timing case: metal gasket
Posted: Thu May 12, 2011 8:05 pm
Hi All
I am about to replace the original 1990 M42 timing case with an e36 1993 version, the one that eliminates the idler sprocket.
The gasket to seal the case to the block is metal.
Any tips to install correctly, or same procedure as with the fibre gasket.
TIA
TIA
