Do e36 318 DIESEL turbo manifold's fit in the e30 m42
Posted: Sun May 02, 2010 8:25 pm
by Alburglar
Hi
I, like many others, want to make the most of m42 forged internals and turbo it. There are loads of aftermarket e36 turbo manifolds available, but I can't find any e30 ones. So will an OE 318 turbo manifold from a diesel 318 e36 do the job, or will i have bulkhead/ component clearance issues?
Or has anyone seen any specific e30 manifolds for sale?
- I just want to run 10psi and see what happens!
Re: Do e36 318 DIESEL turbo manifold's fit in the e30 m42
Posted: Sun May 02, 2010 9:40 pm
by Touring Whore
Just replying because I want to see the responses to this...
Turbo'd M42
Posted: Sun May 02, 2010 10:44 pm
by chips
Looks like you would need an adapter plate or something to get it to fit as the bolt holes dont look like they are in the right place for an m42 head.
Any idea what the port spacing/shape is like?
Posted: Sun May 02, 2010 10:49 pm
by jbh
this could be intresting...
Posted: Sun May 02, 2010 10:55 pm
by chips
Also I'm assuming that this manifold is designed for the turbo to be mounted down below;
Is there enough space down below next to the steering column?
If the manifold was rotated and the turbo stuck up next the head, it looks like you would need another modification to move the turbo away from the head a bit.
Definitely interesting though. I shall be watching
Posted: Mon May 03, 2010 2:21 am
by Alburglar
I have made someone an offer of £120 delivered for the one pictured. I figure it's worth a punt at that price. So, all keep your fingers crossed!
Posted: Mon May 03, 2010 11:12 am
by ade36
Hmmmm, also want to keep an eye on this.... If it works that could be very cool indeed!
Posted: Mon May 03, 2010 11:27 am
by appletree
i'm sure the m42 head has round exhaust ports and a square 4 bolt flange per port to hold it to the head (although i think most flanges only use 3 bolts as the header gets in the way of the 4th hole, as for positioning i dont think there would be enough room to top mount the turbo especilaly with the coil packs were they are in the oem position although you could fit a COP conversion plate to gain some mor space.
still i think by the time youve made a adaptor plate to mount the manifold you would be to close to the chassic rail to do a bottom turbo build.
Ant did a bottom turbo build on a M40 and had to put the turbo near the front of the engine were the A/C compressor would go to miss the engine mount, i'd guess you would run in to the same problem..
Not much space..
Posted: Mon May 03, 2010 11:38 am
by chips
Heres the M42 manifold so you can compare the bolt holes and port spacing/shape.
Posted: Mon May 03, 2010 11:41 am
by chips
Here is another option you could consider; using the standard M42 manifold turned upside down as the bolt pattern allows it.
Unfortunately the turbo has to be located fairly far from the manifold, but its an option to keep things cheap.
http://s824.photobucket.com/albums/zz161/mitchj5/
http://m42club.com/forums/showthread.php?t=11297
Re:
Posted: Mon May 03, 2010 7:17 pm
by Alburglar
I just bought the manifold and turbo, and ordered an m42 exhaust gasket to offer up to it, so watch this space!
Posted: Sun May 09, 2010 11:47 am
by Alburglar
Doh!
Re:
Posted: Sun May 09, 2010 11:50 am
by Touring Whore
Back on the eBay it goes
Re:
Posted: Sun May 09, 2010 12:27 pm
by chips
Oh well, it was worth a try.
You've probably seen it before, but this is the one I think I will be using. It's been used for loads M42 turbo's, with the end 2 cylinders chopped off and used upside down so the turbo sits up next to the head.
http://cgi.ebay.co.uk/BMW-E36-TURBO-STA ... 2eacea6bb5
Re:
Posted: Sun May 09, 2010 6:12 pm
by Alburglar
Yeah, I think that's the next port of call. or a super charger
Re:
Posted: Sun May 09, 2010 7:49 pm
by theduck
Supercharger much simpler surely?
Re:
Posted: Wed May 12, 2010 7:19 pm
by rix313
Maybe this would fit an M40?
Re:
Posted: Wed May 12, 2010 8:16 pm
by theduck
I see what you did there, it wont though, this is an M40 turbo manifold
http://i3.photobucket.com/albums/y83/li ... G_2031.jpg
Re:
Posted: Wed May 12, 2010 8:46 pm
by rix313
That's an M42 turbo manifold.
This is what the M40 standard manifold looks like:
http://bmwfans.info/parts/catalog/E30/2 ... _manifold/
Stud pattern looks the same.
Re:
Posted: Wed May 12, 2010 9:59 pm
by theduck
oh right, bloody american doesnt even know what engine he's got! lol.
Re:
Posted: Mon May 17, 2010 10:51 am
by Mikede
oh stop being sour b/c we wasted all that Tea......j/k
Re:
Posted: Mon May 17, 2010 11:52 am
by theduck
Did this sell in the end? If its in your way and you want shot I might be tempted to have it off you... looks like it might fit an M40.
Re:
Posted: Mon May 17, 2010 7:56 pm
by rix313
Go on Stu ;)
Re:
Posted: Thu May 20, 2010 8:06 pm
by Alburglar
It is still for sale.
I will post it out for the same money I bought it. £120 delivered.
pm sent
Re:
Posted: Tue Jun 01, 2010 6:26 pm
by Alburglar
http://www.e30zone.net/modules.php?name ... 83#1883383
It's on ebay now, incase anyone is interested, I've posted the link in the for sale section
Re:
Posted: Wed Jun 02, 2010 10:26 am
by spassmit69
Re:
Posted: Fri Jun 04, 2010 10:54 am
by Alburglar
nice. just one zero too much with current pocket money
