BMW E30 318iS, 318i, 316i fuel pump
rix313
Wed Apr 22, 2020 8:28 pm
I see lots of posts on the insufferable Facebook groups asking about fuel pumps for these models. So in the vein hope that people do search for things before; check out the Sytec ITP344 fuel pump. Direct replacement and very reliable and inexpensive.
https://www.glencoeltd.co.uk/hi-in-tank ... 580453019/
Wed Apr 22, 2020 9:25 pm
Certainly a good price. The pic. shows the complete pump assembly for an E30, but doesn't acknowledge that there is a one pipe assembly and a two pipe assembly, depending on which tank you have. The pic. shows a one pipe assembly, as far as I can see, which cannot be used on a tank that requires two pipes (although the other way around can be used).
Or is it just the pump, filter, a piece of pipe and hose clips that are supplied for fitting to your existing frame?
Edit: Just found the pump from Glencoe Ltd for £49.00, and that site clearly states that the frame isn't included.
rix313
Fri Apr 24, 2020 5:44 pm
Yes quite Brian, maybe I didn’t make it clear the intention of the post was to inform people of a replacement pump that can be fitted to the standard assembly, rather than the entire assembly :)
TheDutch
Thu Dec 03, 2020 8:10 am
I put a Bosch 0 580 314 070 in my 318is. It wasn't hard to incorporate with the existing assembly. It was about £90 (albeit a few years ago).
YODI
Thu Jan 13, 2022 5:02 pm
And here I am, Via google, whilst looking for fuel pumps for my 91 'IS'
I will order this shortly, I don't know its my issue but for £50 it's good to change anyway.
:banana: :banana: :banana:
rix313
Sat Jan 15, 2022 7:15 pm
I’m glad it worked bro 8)
I’ve fitted a few to my own and customer cars and they’re great.
YODI
Thu Jan 20, 2022 2:17 pm
About to tackle this, any tips or is it literally a swop over with two wires to solder?
rix313
Sat Jan 22, 2022 10:21 pm
Yep that’s all it is mate
