Idle rising and falling
Posted: Sun Feb 20, 2022 5:39 pm
by Phid
Got the M50 running - sounds sweet and smooth but when warm idle is rising and falling, I put the wipers on and when I turned them off it temporarily settled. So maybe an earth? Or could it be a sensor - o2?
Re: Idle rising and falling
Posted: Mon Feb 21, 2022 7:40 pm
by Phid
Further info. The rhythmic rise and fall of revs only happens once the engine reaches temperature. If I disconnect the MAF it has no effect. If I disconnect the O2 sensor the engine idles smoothly. Is it as simple as this sensor is buggered?
Also, the M50 loom has an Evap sensor terminal. On the assumption that the car and original fuse box does not have air con I have just left this terminal. Could this be contributing? Do I need to plug something into it?
Posted: Mon Feb 21, 2022 7:54 pm
by Phid
Just reading up on the Evap sensor. Nothing to do with the aircon. So guess this could potentially be causing my problem. Will have a search around tomorrow night.
Posted: Mon Mar 21, 2022 6:56 pm
by Phid
In case anyone looks back at this - it is now solved. Combination of a vacuum leak and 4 year old fuel!
Posted: Tue Feb 27, 2024 5:46 pm
by Corasdad
Glad you got it sorted
