Various Questions M50B25 NV
Posted: Tue Dec 31, 2019 8:59 pm
by T_Dub
Hi all,
So I bought a M50 swapped E30 a few years ago. Just starting to get around to looking at it.
I think it was never started since it doesnt have the harnesses spliced together. Issue is, I started looking a little deeper and I found some concerning things.
There is a 413 ecu in it. I know this is not a good idea. Is there a quick reference for me to check to see if this guy swapped the cam sensor and crank trigger?
Do I need to run a fan on the engine? Or is an electric fan sufficient?
Is there a way to find out what production date car the engine came from by the engine serial? That would help me track down a replacement engine harness and ECU.
Re: Various Questions M50B25 NV
Posted: Fri Jan 03, 2020 12:08 pm
by T_Dub
So to answer my questions:
Sensors on engine appear to be regular non-vanos. MAF plug was spliced on to the harness to run the early MAF so its defintely a vanos harness.
Going to run a SPAL puller fan that the PO graciously left me in a box and remove the mech one. Theres a new rad on it.
Engine came from an early E36. Trans is a G260 with white325is' crossmember. I'm still not sure about that crossmember though I understand he was the guy for them. Might beef it up a bit.
Found a 403 ECU on ebay for cheap so I snapped that up. Now I just need a manual E36 non-vanos harness.
Only cut wires on the body electrics are the ones that go to the missing cruise actuator. I'll have to get a new actuator, I assume the E30 actuator can be hooked up to the E36 TB.
