Brake servo and lines
Posted: Thu May 31, 2018 7:17 pm
by salam0506
Hi All,
Looking to start with the brakes on my e30 318 swap to m52b28 engine and just wanted to check if anyone has used the kunifer made to order pipes off ebay:
https://www.ebay.co.uk/itm/BMW-E30-3-se ... Swo0JWPbp0
Since i am swapping from a 318 to the 325 brakes is that all i need to ask for? Are all the 325i brake likes the same? Is it worth not getting the hoses from him and getting the braided hoses instead?
The servo i was going to buy:
https://www.ebay.co.uk/itm/New-Genuine- ... SwOA1aKe-I
or is it not really worth buying a new one?
Sorry for all the questions - just a bit aprehensive to spend money on the wrong stuff.
Re: Brake servo and lines
Posted: Tue Jun 05, 2018 12:54 pm
by salam0506
hey just my clio brake servo through the post off ebay and it looks the same dimensions as the BMW one that came off my 318:
https://www.ebay.co.uk/itm/302458424319
Did I get the wrong one?
What should the dimensions be?
Posted: Tue Jun 05, 2018 3:45 pm
by salam0506
i just got this message from the ebayer:
"This one is from a Clio III from 2006 - 2012, they are a bit bigger than the Clio II from 2001 - 2005.
All the Clio II ones from 1998 - 2005 sport and non sport are more or less exactly the same and are all the same exterio dimensions, so if this one is too big, it's because its a later style Clio III one."
Should I change it for the ClioII from 2001-2005?
Posted: Wed Jun 06, 2018 11:35 am
by joeyb
Yer I went for a phase 2 Clio servo so sounds right.
Posted: Thu Jun 07, 2018 1:18 pm
by salam0506
Thanks @joeyb
Could you check the dimensions of yours though? I just dont wanna have to take it back out when I go to fit the engine
Posted: Fri Jun 08, 2018 10:33 am
by joeyb
It's definitely noticeably smaller than the standard E30 unit. I'll nip out in a second and measure it
Posted: Fri Jun 08, 2018 11:07 am
by joeyb
Mines from a 2004 Clio 1.2 with ABS, it measures 220mm across.
Posted: Mon Jun 18, 2018 11:17 am
by salam0506
cheers joeyb - I checked mine and it is 270mm across so I definitely ordered the wrong one. I have sent it back now and waiting for the new one.
Posted: Mon Jun 18, 2018 11:20 am
by salam0506
joeyb - have you run new brake lines from the servo? What are the best clips to use to secure them to the underbody?
Posted: Mon Jun 18, 2018 12:51 pm
by joeyb
No I didn’t run new lines mate.
I fitted my servo yesterday, easy enough to install but I had to drill out the bracket on the cabin side as the locating pin was slightly bigger than the existing holes.
Posted: Mon Jun 25, 2018 6:12 pm
by ceige85
with this swap does anyone notice a huge amount of initial pedal play? seems really soft and hard to meter in the power
Posted: Mon Jul 02, 2018 10:56 pm
by sean1989
ceige85 wrote:with this swap does anyone notice a huge amount of initial pedal play? seems really soft and hard to meter in the power
I’m interested in sorting this problem out too, if feels like the servo is getting too much vacuum
Posted: Tue Jul 03, 2018 10:03 am
by ceige85
I’m interested in sorting this problem out too, if feels like the servo is getting too much vacuum[/quote]
Think I'm just gonna sack off the servo and go for a delete kit straight to the master. Pay the price with cold brakes initially but better than a sketchy feeling when driving hard!
Posted: Tue Jul 03, 2018 10:13 am
by sean1989
Yeah not a bad idea, I think we could just change the one way valve to a lower psi one?
Posted: Tue Jul 03, 2018 5:18 pm
by ceige85
I did wonder if the 6 cylinder would be hauling at it too much compared to a wee clio. Good point
